What to do with old 2.0 rack?
andersman02
Garrett
Minnesota
Bronco Big Bend 2.7l SaS
Put in a severe duty rack..
Any idea what I can do with the old one? Seems to be a waste to toss a good rack, also it's big enough to not want to save as a paper weight.
Pretty sure you can't reuse it on a different bronco either...
kodiakisland
Arkansas
I’ve kept mine as a spare. Should be no problem using it on any other Bronco.
jtgensler
Jamison
Clarion, PA
2022 Bronco, 1996 Tacoma
I'd save it as a spare.
I saved mine even though it was water damaged.
It's not automatic that another 3.0 will be readily available.
Also, if you take the tie rods off, they should be useable with the 3.0, in an emergency (getting off a trail) situation... Yeah, they're weaker, but if I understand correctly, they're the same length & thread pitch, so...
Valhalla
Valhalla
Chattanooga Tn
An attic or crawl space will be happy to hold your spare, that is where mine slumbers at my abode.
KABQ
Aaron
Albuquerque, NM
The answer is always "go kart"
