What oil are you running in your 2.7L?
SnowBronco
Canada
Amsoil 5-30 signature since 2000 kms.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Arc
Alan
Sc
Gmc 1965 4x4 SS Elcamino 72
I did my first oil change at about 2,800 miles, then second after about 8,000 miles. The recommendation from Blackstone Labs was to go 8,000 for the next change, then see what the TBN looks like and possibly go 10,000 miles. As for tire rotations, I go 4-5,000 miles between and do a five tire rotation.
Ford Bronco What oil are you running in your 2.7L? 20230604_192705
JR
I also did everything it like you borrowed my sheet except tires I changed them.
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
Ford Bronco What oil are you running in your 2.7L? 20230503_100851
After this thread, I actually added a column for tire rotation interval. I also have this for my Mustang and my wife's Mercedes. The Mustang has like 35 lines of maintenance/upgrades/dealer recalls and service.
JR
Bronck
Troy
Richmond va
Honda
Motorcraft full synthetic. Is it bad?
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
Nope! It's very well reviewed and tested. Unfortunately, it's also tougher to obtain than most of the other oils listed in this thread.
JR
Combustion_King
Derek
MA
Yes
First oil change was at 6k +/- I use Mobil 1. All street vehicles I've always used Mobil 1 In my bikes i use Redline.
I did the tire rotation at about 5k, with a 5 wheel rotation pattern,
Ground_zero298
Scs michigan
I run valvoline. Oil be oil. Eating money buying high end oil for a budget vehicle.
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
Castrol Edge
Liqui-Moly with Molygen
Amsoil
Those are the 3 oils I typically use depending on application. I'm planning on the Liqui Moly in the Bronco.
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
A $55k truck with a high technology twin-turbo V6 that's prone to cam phaser issues. An oil change costs less than $100.
JR
Ground_zero298
Scs michigan
JR
A 33k truck with a rattle box v6 with tiny snails. It’s just a lower mid end vehicle. Nothing special about it.
It’s not prone to cam issues. You either got a good one or bad one.
CarGuy
New Jersey
2023 Ford Bronco
Ditto! It’s not high-tech at all. Any good quality oil and timely oil changes should keep it healthy for years/miles.
