What offset are you running?
kirby149
Greg
Arkansas
F-150
I’m looking at fuel trophy wheels with +6 offset. Worried they may stick out to far. Bronco I have ordered is a 4 door bigbend will be adding 2 inch lift. Any thoughts??
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
0 offset on 8in wide wheels. Perfect poke for my liking and fit just right with SAS flares
Copperhorse73
Justin
Mooresville, NC
If you don’t like poke, stick to something closer to Factory or get some Sasquatch flares, and still stay close to factory. However if you plan on putting 37s on in the future you’ll need less offset such as 0 offset on 8.5” rim
CJ1064
Clifford
Monmouth County, NJ
GT350, Cherokee
I went with -12 to replace my SAS and I love the look and stance. Won't really be doing any off-roading
BroncoAZ
Mitch
I measured the horizontal distance from the flares to the edge of the tread on my Badlands 285/70R17 tires with a plumb bob off the edge of the flares. I had 30mm in the front and 25mm in the rear. +30mm Sasquatch wheels with 285/70R17 tires should align the tread perfectly with the outer edge of the standard flares. I’m going with the same Method +35mm wheels that @LHD is running, going for that no splatter up the side of the truck goodness.
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
17x9 +1 offset Fuels with 35x12.50 Nittos. I bought some non squatch flares, and I liked the way they look with the factory Sasquatch tires/wheels. Now with the +1s, I’ll probably put my Sasquatch flares back on.
MiracleMan777
Justin
Lowell, IN
2021 Bronco Big Bend, 2010 F-150 Lariat
+20 Offset 20x9 Fuel Rebels on non-sasquatch. Sticks out a 1-2" beyond flares. I like the look of the poke.
rabidmoravians
Jason
Jeep
Please post pics if possible of these different offsets. I want to swap my Sasquatch wheels out and am not sure how different offsets will look. I really wish I could have just gotten the black steel 16s from the black diamond. Any pics would help. Thanks
Utahjazzman
BJ
Ram 1500
17x8 Outlaw II's with +18 Offset. Minimal poke with stock non-SAS flares.
Thanks for doing this. Do you have the stock 285/70-17 BFG tires or something different?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Please also list your tire size as this can impact how much poke you get. Thanks!!
Yup, I have the same offset as Dez up there but waaay more poke, more than I really wanted. I kind of regret going with 315s.
Dez
Geoff
Framingbury, MA
1967 Mustang, 2021 Hyundai Kona, 2021 Ford Bronco
Yes and no. Since mine is a big bend they are not stock size but are the stock tires/size for the badlands. 285/70/17 BFG KO2's.
I think the fact that my wheels are 17x8 also helped keep the poke in check. The backspacing of the wheels is 5.21".
