What Mudflaps do you have installed?
Dirtrider
Bruce
St. Louis
Honda Ridgeline, Super-C Motorhome
What have you all got? Should I go with the Ford ones? Putting them on my BadSquatch once it arrives. Saw a raptor that had ones added that looked ridiculous, don’t want that to happen. Pics?
The Inexpensive Ford ($59?) fronts don't work with the OEM rock rails. I have a 4 door BD non-sas and I chose the IAG (same as Mabett) but fronts only. I don't particularly like mud flaps but I like mud covering the sides less:) These should be less visible with the wider SAS fender flares than they are with my non-sas BD. The only thing I didn't like is using the fender liner plastic snap in pin for the inner mud flap retainer. Since mine is non-sas I have the crash bars so I made a 3d printed retainer/plug that slides into the end of the rear crash bar to hold the inside of the mud flap. No fiddling with the plastic snap in pin, easy in, easy out.
Ford Bronco What Mudflaps do you have installed? 1685729186277
Ford Bronco What Mudflaps do you have installed? 1685729241113
Ford Bronco What Mudflaps do you have installed? 1685729391024
Dirtrider
Bruce
St. Louis
Sorry for the double images, don't know how that happened:(
timhood
Tim
Several
OEM front flaps only. Had to modify to work with the Badlands rock rail, but in the end, it was worth it. I think this is a rare case where the OEM part looks as good or better than any after-market part and costs less than any but generic ones. I took some advice from @MFP2241 and just cut a hole for the rock rails. The end fit looks clean and these guards do an excellent job of keeping mud and rocks off the side of the Bronco. Photos/discussion here: #86
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
Well put 👍🏻
B Miller
Sherwood, OR
I had the ones from Mabett. They were great and easy to install. But wanted to take them off in fear of breaking them when dropping down off rocks ect. Instead chose to bring them in under the Bronco. Here's the results. The factory tires did throw lot of rocks. These new Toyo Open Country R/T Trail tires do not throw rocks. Just another option and some information.
Blue Hen
Delaware
18 Suzuki Vstrom 650XT, 22 Bronco Base MT SAS
I went with Rekgen XL. Reading all the stories on Territory MT tires. Mine didn't come with direction. I received help from one of the members on here. They sent me instructions from their kit. Very happy with function and look.
Ride Em Bronco
Al
Pittsburgh, PA
2024 2-door 6-Speed Manual Big Bend Bronco
I am on the Ford Build and Price for the 2023 Bronco 4-door Big Bend and see that I can order the OEM Front Mudflaps - which I assume will either come installed on the vehicle when delivered or will be installed by the dealer upon delivery. But I do not see the option for also ordering the OEM Rear Mudflaps. Yet the Ford Build and Price photo of the Bronco shows BOTH Front and Rear mudflaps on it. Side steps and rocker panels are not the issue as neither are being ordered. Can anyone explain??!!
Nobroncoyet
Ohh
Phoenix
I'm surprised not many mention " Rally Armor". They are amazing
WT are stiff and if you off road will damage your car because the flaps don't flap
Mabbet is a Chinese product and i ain't paying CCP
Rokblokz are a decent option but once you try Rally Armor is hard to go with other option
omi205
BoJack
Austin
Im not seeing how this solves the problem. The clips towards the end, where he shows after riding through mud...are not good (personal opinion). The entire side of the vehicle is still getting hit with mud/rocks (significantly). Mud flaps, would completely remove that or significantly remove that spray on the doors. I have the sas package which comes with the extra wide fenders. They do not, in anyway, solve the problem or replace mud flaps. There is a gap between the fender and then rock rail that still remain wide open. This is what needs to be closed. Again my personal opinion of riding a Badlands Sas. Mud flaps and proper rock sliders that extend outwards would almost entirely remove the spray that is shown at the end of the clips.
B Miller
Sherwood, OR
Gotcha. The tires were the main issue in regards to rocks. Replacing them solved 90% of the problem. The issue I was having was mud caking the door handles and getting all over the windows. Bringing the tires under brought the dirt line down a lot. I will always have mud on the side, just not as significant. In the video, the red line shows how high the mud gets on the side. Much better in my experience. True, mud flaps solved the issue if you choose to use them. I went this route :)
mike8675309
Minnesota
Weathertech. I like that they have a few bolts that I can pull off when I go on the trails if I think I need the space.
ScottyC
Rome NY
2022 Bronco 4 door
Mabetts here front and rears...easy install.
Ford Bronco What Mudflaps do you have installed? 1688247833702
Ford Bronco What Mudflaps do you have installed? 1688247862734
