Weird shuttering in First Gear anyone else experience this?
TheHuntMan
Hunter
Pennsylvania
1966 Bronco, 1994 Bronco XLT, 2018 Ford Focus
Today while driving my 7 spd big bend my truck started rocking forward and back in first gear while I was driving despite the fact I was actively accelerating it happened again just now not really sure why. Has anyone else experienced this?
MaverickMan
Shane
Hope its nothing too bad. There is another thread with a clutch failure that sounded like a potential pilot bearing being amiss causing a vibration that destroyed it. Could otherwise be a defect in the pressure plate or the disc itself. I hope this is not yours issue.
Was there any break in procedure for the clutch? Or is it assumed that they are driven enough to break them in properly. I smoked a clutch after replacement once while pizza delivery racing and while it functioned fine it was always a lil softer than it should have been.
TheHuntMan
TheHuntMan
Hunter
Pennsylvania
Clutch feels perfectly fine it’s just a rocking no actual vibrations or anything. I think I may just be such a light foot when it comes to accelerating 😂
Lifeliberty
Moonbeam👀
Columbus, OH
Sounds like a brake drag. Is your e brake off?
With new cars i drive them like i stole them, try to break things while you still have the warranty
TheHuntMan
TheHuntMan
Hunter
Pennsylvania
TheHuntMan
TheHuntMan
Hunter
Pennsylvania
Hmm could be a bit of lag in the electric parking brake
TheHuntMan
TheHuntMan
Hunter
Pennsylvania
Update: I got home a little bit ago and I seem to have figured it out. There’s seems to be a little lag with the parking brake and when combined with my light foot causes a weird shuttering. It I hammer it it’s fine and if I don’t set the parking brake I’m fine
MaverickMan
Shane
Nice, I've always found that driving manuals hard makes everything fine in the world.
Lil Red Broncette
Explorer
I am confused here, why doesn't the parking brake release when it is released? I would think there is a second or two after hitting release before putting in gear and letting out the clutch.
Are you starting to drive and letting it automatically release the parking brake?
Or is ford trying to do some fancy crap like hill hold automatically with parking brake when stopped?
Or maybe it takes several seconds from hitting the electronic release till it actually releases?
I am not a fan of the electric actuated parking brake. Maybe there is some true benefit, but it seems odd. Maybe save the old problem of parking brake cable rusting? I would think there is just as much risk of the actuator having problems. The latter may be easier to replace however.
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
Some modern cars have a hydraulic line for the parking brake, with the piston actuated with the hand lever. No cable to worry about. That’s what I wish the Bronco came with.
Lil Red Broncette
Explorer
That sounds like a nice solution. I will say I prefer a basic non electric brake.
And since I come from the school of the "parking brake" also being the "emergency brake", how the heck does one control the electronic parking brake in a moving brake situation.
Bradnewt
Brad
Hot Springs, Arkansas
Jeep Wrangler
Go to your Ford account and watch the how to video explaining how the hill holder feature works.
Drex
Jake
direct injection only engines are notoriously difficult to meter fuel evenly at low RPM, low throttle, and high load (low gears amplify the effect of surging due to the large O2 feedback swings under those conditions). A light throttle application may just be exposing the nature of this heavy beast, especially if going up a grade/hill.
