Weathertech no drill mud flaps
RBJRBJ
Bruce
2023 Bronco
I have a 2023 Bronco Wildtrak with LT 315/70R 17 M/T 35” tires with Wildtrak fender flares.
Has anyone purchased Weathertech’s no drill mud flaps and installed them?
Do they fit well on a Bronco Wildtrak?
Are they worth buying?
Please advise and thanks in advance.
RBJRBJ
PWillette
Parrie
Maine
pappacrunch
Kevin
55 Ford F100
They were the first purchase I made a month ago for my Wildtrak. I put them on the front and back. Install is easy. Especially if you take the fender flares off and give yourself a little room to work. We have put a little over 3k miles on the Bronco with them on and every now and then you hear them take a rock that would have smacked somewhere on paint. No wind noise related to them. I would buy them again.
MyATV
ATL
There are over two (2) dozen threads on this topic.
They're funky-looking, but they keep the mud off.
Scott R Nelson
Meridian, ID
I put the WeatherTech mud flaps on mine after a few trips driving in mud. It was clear that I needed them. The only hard part of the installation is getting the plastic things out of the fender liners. Putting all of the bolts in was easy. Be sure to use red Loctite on the large bolts for the rears.
Photos right after installation:
Ford Bronco Weathertech no drill mud flaps KaWdGLG
Ford Bronco Weathertech no drill mud flaps QDyuKZe
Mlarv
TN
I put the Mabitt set on BL SAS. They look pretty good as far as I am concerned. They come off pretty easy if you want to go play in the rocks and mud. There is no gap between the fender flair and the mud flaps. Mud Flap
I did the weathertechs on a '23 Big Bend.
The only deviation from the provided instructions were on the rears - there was one bolt that was mentioned in the instructions that there was supposed to be a threaded bolt hole but on mine it was just a body clip - it didn't have a bolt hole on the chassis. I was able to re-use the plastic body clips from the front flaps in the spot and it's held up fine so far.
They are ok and look fine. I'm fairly happy with them. I got them with the floor mats and rear bed mat - the rear mat is is absolutely worthless but everything else worked out fine.
CarGuy
New Jersey
2023 Ford Bronco
RBJRBJ
I went with Broflaps with the removable extensions. They fit great.
Ford Bronco Weathertech no drill mud flaps IMG_1233
