Weather Stripping Defect?
tock13
Tony
WA State
It’s the bronco version of the crack Wrangler TJs get down the top center of the door panel. “oh, that’s normal, no worries”
Anyway, my Broncos passenger side has the seal bulge, driver side doesn’t. Go figure.
HeliPilot
Kenny
CT
2022 2.7L SAS
Agreed. This seems like a QA thing on a cheap part of the car. One would think this would be an automatic replacement. I have reached out to the Ford rep on here. Was pleasantly surprised to see that as this is my first post. Thank you to everyone who has been chiming in!
I will say that mine appear to be tucked underneath the plastic trim at the bend. Yours are not. You may just need to tuck the rubber under the plastic at the bend.
jsoa
Jose
Delaware
2024 Bronco 4dr
I had the exact same issue, dealer fixed (ordered a new one) under warranty
Ford Bronco Weather Stripping Defect? PXL_20240220_015301692
Ford Bronco Weather Stripping Defect? PXL_20240220_015310419
CarGuy
New Jersey
2023 Ford Bronco
I have the same issue on the driver side. Seal works fine.
malpais
Some old Honda
I also have them on both sides. Driver’s is worse. Neither leak nor whistle so I didn’t bother to do anything about it. Mine is a 2024.
RBJRBJ
Bruce
2023 Bronco
Not on my Bronco.
Bobio
Bobby
United States
2024 Bad lands
Mine has it as well on both sides in same spots. 2024
GRB1959
Gordon
Aurora, CO
2021 Ford Edge ST, 2024 Ford Bronco Badlands
I just checked both the driver and passenger side weather stripping on my 2024 Bronco Badlands and it looks fine.
Ford Bronco Weather Stripping Defect? P1030423
vbrad26
Vance
FL
VW's, an old Range Rover and now a Ford
My driver side has it. the passenger side did as well but I swear it fixed itself over time lol.
When I'm at a stop light, I'll poke at the driver side one from time to time, hah.
ksdon
kansas
Does the dealership have other Bronco's in stock. If yes, go look if they have it.
If they do have it the dealership may balk (even harder). If none of the other dealership Bronco's have that you have ammo to kindly ask for replacement.
Blue Hen
Delaware
18 Suzuki Vstrom 650XT, 22 Bronco Base MT SAS
I have a 22 with the same issue. Both sides.
