Water draining to under dash
mack092
mack
Houston
ford bronco
Please see video. I just discovered the water draining into the dash. Doesn’t seem normal to me. I initially thought waterlogging was due to my skyrider top but seems like the moisture from the AC leaking in. What’s the fix? Anything quick??
Ducati1098
Don’t see any video
Ducati1098
A/C drain could be blocked causing moisture to get backed up.
mack092
mack092
mack
Houston
ford bronco
But I still get water dripping under the vehicle. Lol it’s going both ways?? I have had this before with a different car, it shorted the speakers in the door.
Ducati1098
Well it appears to be coming from the HVAC case. So it’s either water or coolant. Either way it shouldn’t be coming out of there.
If the drain isn’t clogged, looks like it’s time to remove it 🤷‍♂️
helifino16
Ron
Mount Sinai, NY (Long Island)
Bet you're really missing that Washout floor now?
