Warn 8274 install
camojeeper
Occupied territory behind enemy lines
22 wildtrak
Like most of you I waited 2 years for my bronco. Buying parts and stacking them in the shop impatiently waiting to receive my new toy. I ordered my 2DR with the factory winch set up but ford zeroed it and my bronco went into production. Ok no biggie right? So I have had a few LOD bumpers over the years and have been happy. So I ordered the LOD defender. Then onto the winch? I think the ole 8274 would look killer on the new bronco. Ok now comes the head aches. The 8274 mounts from the front not the bottom. Out comes the torch to open the top of the bumper to clear the side gear of the winch. Then onto building up the bumper where I modified it to accept the 8274. With some 3/8”steel I was able to pick up the top 2 mounting holes and really beef up the bumper where I weakened it by cutting the top out. I also added a camera mount and fabricated an ACC mount to relocate it under the bumper.
Ford Bronco Warn 8274 install F174A4A1-BE84-4B26-81C1-3772C1DDB046
Ford Bronco Warn 8274 install 53CC6A32-2ECB-43A2-A8BA-0C5213071D00
Ford Bronco Warn 8274 install 17E958AB-37C0-46C7-9188-0B65CAA57714
Ford Bronco Warn 8274 install 7CAFE6B9-985B-44C0-8B7F-45E2B1327F2A
Ford Bronco Warn 8274 install D250ABDB-1007-4F1C-A656-3D535777188B
Ford Bronco Warn 8274 install 64A89B78-BB54-4864-97D9-234806853B13
camojeeper
camojeeper
22 wildtrak
Here’s a couple more pictures
I also had to order a camera cable extension and washer hose kit to extend the existing ones I was about a foot short of the factory stuff working
Ford Bronco Warn 8274 install 9257903F-61C5-42F4-BB06-EBA725D219AE
Ford Bronco Warn 8274 install 239C7AFD-7651-4581-A388-5C5221949DF9
broadicustomworks
Hanging Rock, North Carolina
Quick question- Where did you source the extensions to relocate the camera?
Easy way for me is to buy a kit, modify the mounting bracket for my use.
Cheaper way is to make my own bracket and source the extensions.
camojeeper
camojeeper
22 wildtrak
Bingfu Fakra Z Female to Male Vehicle Antenna Extension Cable 2m 6.5 feet for Car Stereo Android Head Unit GPS Navigation FM AM Radio Sirius XM Satellite Radio 4G LTE TEL Telematics Bluetooth Module https://a.co/d/gQD64in
I only needed about a foot so I would probably get the smaller cable they offer.
Windshield Washer Hose Kit - 4 Meter Universal Washer Fluid Hose with 12 Pcs Hose Connectors, Suitable for Most Windshield Washer Nozzle Installation, Connect Car Water Pump and Nozzles https://a.co/d/hfeqsRu
both kits are out for delivery so I will know tonight for sure everything plays well together
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
Any idea of the weight of the winch and bumper......got to be 150+?
camojeeper
camojeeper
22 wildtrak
Any idea of the weight on the winch and bumper......got to be 150+?
Every bit of that I would guess 200 ish. My 2DR is 5500 pounds with a full tank
camojeeper
camojeeper
22 wildtrak
Winch and cable are probably 75lbs.. plus the bumper
The 8274 is 130 lbs with 125’ of 3/8’s cable. It’s a heavy bastard
Bikeric
Tulsa
2022 Badlands LUX on 37's
I really like your camera relocation. I think I might have to do that too.
Ford Bronco Warn 8274 install XyB4iNr
Ford Bronco Warn 8274 install BuscazU
tobyw
Toby
Washington
2022 4-Door
Nice fab work on the bumper modifications to accept the 8274, I dig it... The ACC mount, however, I'm not so fond of. I have no idea what kind of wheeling you anticipate, but the first time you push bumper-deep snow/mud or attempt a decent size rock face, that looks as though it will bend back/forth as you work for traction. I don't have any better ideas, that pesky ACC is the bane of our winch existence on these things, but maybe come up with a boxed-in solution just to keep it immobilized? Regardless, very nice work and I applaud your efforts (y)
Felix808
SRV CA
This picture makes your winch look bigger than the whole truck :ROFLMAO:
camojeeper
camojeeper
22 wildtrak
I’m not in love with it either (ACC) I’m going to armor it a bit more. It’s mounted now to a 1/4” plate now I’m thinking adding another 1/2-3/4” around the sensor but there’s really no good way to mount it?
camojeeper
camojeeper
22 wildtrak
This worked great easy plug and play. I would get the 3’ cable for the camera not the 6’ that I did
Ranbronc
Pa
Early Bronco
switching to Rope and a smooth alumium fairlead will lighten that up a bit.
