Ford Performance WARN winch kit install by service tech
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
I follow this veteran-turned-mechanic on Youtube. Works at a Ford dealer I believe somewhere in the Chicago area.
Today’s video is installing off the WARN winch kit from Ford Performance accessories.
dcg2
Don
PA
Honda CR-V
Other than the ginormous billboard that is the front license plate bracket. And the stubby push bar that does what exactly??
What's to keep you from relocating the control module to somewhere that doesn't block the front camera??
Does the car need reprogrammed because the ACC is blocked? Not clear on why that needs done.
I do like the beefiness of the frame reinforcements on this kit.
Mikerider
Washington
Raptor, Ranger, Mustang, Focus, Explorer
agree totally like the bracket system and the additional strength those will provide.
the reprogram looks to disable the front park sensors so there's at least that.
LCW
Twin Cities, MN
2019 4R TRD ORP, 2023 Bronco 2dr Badlands (gone)
Anyone added the FP winch kit to the CAPABLE front bumper?
RagnarKon
RagnarKon
Bryan
New England
Not compatible.
Ford Bronco Ford Performance WARN winch kit install by service tech 1691951006490
BUT... I'm actually looking into it. I think you can build a pair of adaptor plates to make it work.
I can tell you right now it will NOT work if you have the High or Lux package. The front sensors are located in the exact spot where the winch would mount.
  • Like
Reactions: LCW
Ninjak
Miami
Interesting. I have a WARN Winch, the same as Ford use, but again I have WARN front and back Armour. So...Meh. But I think I read it wrong, its for the Ford bumpers. So lol L2read.
RagnarKon
RagnarKon
Bryan
New England
Not compatible.
Well... got an update for you @LCW ...
It works!! Albeit with some minor modifications. Not sure if it'll work with the sensors though, but you can give it a look and see if it is feasible.
Ford Performance WARN winch on capable bumper — Yes it is possible!
  • Like
Reactions: LCW
LCW
Twin Cities, MN
702BroncoGuy
Howard
Las Vegas NV
2023 2dr Badsquatch, 2013 370Z
Interesting how other manufacturers of winch plates don't mention/suggest that from what I've seen.
Yah I don't think it would be possible since Ford knows the exact specs of their Winch plate etc. so they can do the calcs for their equipment.
