VRTUNING FOR YOUR NEW BRONCO : AVAILABLE NOW AT LETHAL PERFORMANCE
Blaven
Pennsylvania
Bookmarked for when I actually do get my Bronco. Those are impressive numbers.
internationlriders
Josh
Alberta Canada
2021 Bronco Badlands
Pretty sure I'll give this a go once I receive my Bronco 😅
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
Hey All!
Wanting to boost your Bronco up a notch? Feeling a little limited and wanting more out of it? Well now, we have a great option open to you!
VR Tuned ECU Tuning Box Kit V2
The tuning box kit is a plug and play solution to boost your vehicles performance up like an ECU flash, but without affecting your warranty. The VR Tuned ECU Tuning Box Kit gives your Bronco 2.7 EcoBoost a gain in power from 310bhp to 364bhp!
Horsepower goes from 310 to 364 (+54 crank hp, +45 wheel hp)
Torque goes from 400 to 500 (+100 crank Ft Lbs, +83 wheel Ft Lbs)
  • Plug and Play for easy install and removal
  • No detection by dealer when removed
  • Up to 7 different maps for easy programming
  • Includes bypass plug to run as stock
  • Does not lock to vehicle or VIN
  • Harness has OEM style connectors, no splicing or cutting
  • Tuning Box features a weatherproof case
Check it out below! :
https://www.lethalperformance.com/v...bronco-2-7l-ecoboost-vrt-brc-2-7-dmb7333.html
As always, any questions or want to get something on order? Let us know! Feel free to reach out here, shoot us a call at 561-753-8105, or shoot us an email at [email protected] .
Joe Rocchio / [email protected]
877-2-LETHAL | lethalperformance.com
How does this compare to the Whipple kit? Any plans to test this in-house?
LethalPerformance
LethalPerformance
Jared
South Florida
I really can't comment on how it compares to the Whipple cal as we haven't tested the VR module yet. However I can definitely explain the differences. The VR Tuning module is a piggyback style device. It's plug and play with the OEM map sensor. You will see increased HP/TQ with it and can unplug it at any point without affecting anything.
The Whipple calibration is a full flash of the PCM and TCM. It will increase boost, provide quicker throttle response and make excellent HP/TQ over stock. The Whipple cal also raises the stock speed limiter, raises the rev limiter and also changes the shift logic for higher, firmer and quicker shifts. It also has the ability to read/clear DTC codes and allows you to adjust for different axle/tire size changes. Lastly it disables the auto start/stop feature.
With the Whipple cal you're unable to simply remove it and turn back to stock. In order to return to stock you'd need to request a stock file from Whipple where you would then reflash the Bronco with it once received.
At the moment we don't have any plans to test the VR module. We have sold several of them to our customers and have received great feedback on them so it just comes down to what your personal preference is.
Feel free to reach out if you have any other questions.
Thanks!
