Vin#
HoosierDaddy
__ Eric
Indiana
The link works fine, he can't post the link specific to someone else's build without knowing the VIN and order number. Swap your info into the query string and it returns data.
It's an API call, so it isn't going to be pretty to read unless you are used to reading JSON. Essentially the same data that is being shown on the 6G VIN tool, but with some other extra data.
Considering how many people can't figure out how to use the search function here at b6g, it's far easier to post the link that has a form that will hopefully auto-populate for the simpletons the next 6000 times they check their status until their build gets scheduled.
You and I have now wasted far too many words on dumbing down what should be a simple process.
As far as the IT deficient masses are concerned, that link doesn't work.
K.I.S.S.
dinkdonk
dinkdonk
Cynthia
long beach
Audi Q3
What do you mean, it doesn't work, it works fine, especially if you got data back that matched your vehicle.
More than likely, it is because your vehicle may not have actually been built yet. Remember that there was a production line shutdown or you might be stuck in a QA hold. If you didn't see a release date, then it is likely that it has not left MAP.
Yes - The link you provided does not work - However, the link the other fella provided did - so there's that - but thank you nonetheless -
Ford Bronco Vin# Screenshot 2021-08-04 074859
dinkdonk
dinkdonk
Cynthia
long beach
Audi Q3
dinkdonk
dinkdonk
Cynthia
long beach
Audi Q3
"In Stock" on your dealer's website likely just means that your VIN has been assigned to their system and it automatically adds it.
Window stickers are not assigned until you are 1 week from your planned build day.
If you look at the top of the window sticker, it should say "blend date" and some numbers. Those numbers are the day where they complete the main final assembly of your rig. There will still be time after this till it ships, but this means you are close (pending they don't shut down...).
Eventually you will get a confirmation after its shipped (some have been up to 2 weeks after it was produced) and a delivery window when you might see it.
Sounds like your dealer is just shitty with their communication. Welcome to Ford.
#mydealerwasamazing
wow - this is all useful information - thank you so much.
mpeugeot
Because you have to put your VIN and ORDER NUMBER in there.
