Video on removing badges?
Jmax
Plymouth
Explorer
first sorry… I suck at searching but I have looked at keep going down rabbit holes…
does anyone have video on how to remove badges and apply? I’m more interested in removal because this is my drEam V and I don’t want to F it up! Thanks !!
helifino16
Ron
Mount Sinai, NY (Long Island)
I recently watched the guy from Town & Country scratch the edge and peel off his badlands sticker. Easy as that. If it leaves residue, a little alcohol will fix. It seems to come off clean and several people have reapplied them elsewhere.
Roundabout
I used a plastic putty knife. Took them off easily with very little residue (which cleaned up quickly with a soft cloth and rubbing alcohol). I put one on the rear gate and saved the other one, sticking it on an old tupperware lid.
The Bronco logo on the gate took a little more effort as I was worried about streesing the hard plastic so I worked from different angles until it was safe to peel off. It was the chrome colored type, wanted gloss black. Found they are on back order everywhere and about $50 after delivery charge so off came the old one and spray painted it, removed the old tape under it, cleaned it up, new tape, done.
BTomorama
Atlanta, GA
2015 Nissan Rogue
A warm/hot day or a hair dryer (what I used) helps remove them with less residue. The heat causes the badge to stretch a little bit, however, it makes it less likely to be reused.
Portapot
Maryland
Cj7, RX350, f250,
My dealer said people are removing them with poly fishing line which makes a lot of sense to me. Kind of like a big flossing.
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
That's what my plan is, just have to get off my butt and do it.
Blue's B6G
Jeremy
Los Angeles
2021 Bronco OB 2-Door V6 Sasquatch AMB High Pack
1. You should rarely listen to an auto dealer.
2. You don’t need finishing line or any tools at all beyond your fingernail.
3. It’s just like, I don’t know, peeling a sticker off anything else.
4. The scripts are played out already. And they look weird on a four door.
Portapot
Maryland
Cj7, RX350, f250,
To each his own....you do your thing.
SigSauer226
James
1965 Ford Mustang Fastback, 2011 Ford Mustang G
I used a plastic putty knife. It doesn't scratch and has a tapered edge so it gets right under the decal. VERY EASY and it came right off first time. Just get the edge and then pull. Super sticky still to reapply. I reapplied it right away so no idea if it will be ok if you wait. I used alcohol and cleaned any residue but there wasn't much.
I was a bit nervous but it came right off no problems. Highly recommend the plastic putty knife. Was easier than I imagined.
broadicustomworks
Hanging Rock, North Carolina
The sticker badges and the actual hard emblems are two different animals.
Badges will peel like any vinyl would. This time of year in most of the country, a hair dryer will aid in removal.
The hard emblems, yes, fishing line sawing back and forth behind it, some rag and alcohol once you get tired of peeling the adhesive off with your fingers.
Amazon.com: 3M VHB Tape 4991, 1" x 5 yards, Gray, Double-Sided, Permanent, High Strength, Long-Term Durability : Industrial & Scientific
This is the best stuff to reapply new emblems with.
Apply it to the back of the emblem, use a razor blade to cut to shape (as carefully and safely as possible), wipe the area you are going to reapply with alcohol one last time, peel off the other layer of film, press firmly across the surface area of the emblem.
SigSauer226
James
I'm actually in the minority and I wanted to keep the Badlands badge. I like it but I also wanted the old school Bronco script. I just lowered my badges under the script and I'm really happy with the results. Some might not like it but I'm very happy with it.
Ford Bronco Video on removing badges? Screenshot_20211115-091003
Ford Bronco Video on removing badges? Screenshot_20211115-091111
Ford Bronco Video on removing badges? Screenshot_20211115-091136
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Looks good. I've been tempted to relocate mine to that spot. Right now I have one on the tailgate above the handle equidistant to the Ford logo below. It looks.... okay. My other sticker is chilling out on my toolchest for now. It'd be nice if we could just order replacements.
Jmax
Plymouth
Explorer
Thanks everyone! Seems crazy to me that these badges/Ford/pony are just held on by an adhesive that can easily be removed when it needs to handle extreme conditions desert to frozen tundra to rain… but I guess they have that figured out. I’ll give it a try when I get mine. I’m wanting to replace the pony, Ford, and likely the one or both badges with black/or matte black. Might spray paint and if it turns out bad order new ones in those colors.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
You must be new here. Welcome to the forums! We all know what "My dealer said..." means. :ROFLMAO:
I usually use a hair dryer and fishing line when de-badging a vehicle, however with the Bronco I suspect the fishing line may not be needed; might actually make it more difficult. They look like they come off pretty cleanly with possibly a little heat. Lots of folks have re-used them as they come off pretty easily (thankfully).
Portapot
Maryland
Cj7, RX350, f250,
I wish I was new ..... LOL. 7.13.20 Res been on here a while.
