Using Rear Fog Selector for another purpose
25BBnotsquatch
Jon
2025 Big Bend Standard
Hello,
The wife has a 2025 BB, I am changing the bumper to a mod bumper this weekend. The 2025 BB has no fog light wiring anywhere. I have already bought and installed the front/rear fog selector switch. I have found a few good threads of tapping into the harness for the front fogs. I bought Rough Country DRL Triple LED Fog Light Kit w/ Amber DRL. My goal is to use the rear fog selector for the amber selector and the front for the white LEDs. I dont want to add switches no it doesn't have Aux switches. If you guys know where to tie into the rear fog harness or fuse let me know I cant find anything.
If I dont hear anything I will attempt to locate and keep you updated in a couple weeks.
Thanks for all the help.
VirginiaHeritage
Frank
ā€˜25 Bronco HE
25BBnotsquatch
Jon
No it doesn't have a rear fog harness but you should be able to tap into the BCM after activating it on forscan. So essentially using both fog selectors to differentiate between amber and white fog lights with the Rough Country Lights.
NMWildtrak
Keith
Rio Rancho, NM
2022 Wildtrak
If you have a carplay compatible screen, look into the Garmin Powerswitch. It isn't cheap, but it takes all of the guess-work out of where to wire stuff. Works like a bluetooth aux switch on your dash screen.
SlowTrak
NorCal
It's an SUV btw....
There is a white and blue wire that goes to the rear driver's side bumper plug. Can't remember if every bronco has it or not. It is pin 3 of that connector. If you can catch it at the wires going back along the bottom driver's side panel, you should be able to do it.
