USB output wattage (anyone tested?)
djp
djp
Idaho
'22 Badlands 4dr || '21 Bronco Sport BigBend
  • Thread starter
  • Banned
  • #1
i have a 2.3 three pedal and it has a USB Type-A and USB Type-C ports under the center dash, forward of the shift box.
Supposedly the C spec should deliver more power... but has it been tested?
Has anyone tested the output of the ports to see if the Type-C delivers more amps, thus wattage?
The reason I ask, is the manual transmission model does NOT come with wireless charging, thus I added my own with the USB-A port.
However while charging on the self installed wireless charge pad and having carPlay + apple maps + pandora on the charge cannot keep up with the load and my battery slowly drains
toughtoaster
Kansas City
2012 Mustang GT, 2022 Bronco Badlands
Haven’t got my Bronco yet to test but it should provide enough of a charge through either C or A to keep up with car play. At that point though it’s wired CarPlay which uses less juice. The wireless charging has been known to not provide enough juice when running CarPlay/AA.
I would run these wired if at all possible since wireless charging isn’t efficient and can heat up the phone a lot.
twyoung1975
Wayne
Alabama
1970 C10, Nissan Versa, Jeep Grand Cherokee L
I haven't tested it, but my USB-c charges my phone pretty quickly, much faster than the one in my wife's Jeep Grand Cherokee
CaliBronco92
Green Machine
That's most likely a limitation of the charging pad itself. Most charge at a very slow rate, no matter if the source is powerful or not
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
I have a tester, I'll try it out later today. I wouldn't expect more than 2.1 amps though.
  • Like
Reactions: djp
djp
djp
djp
Idaho
  • Thread starter
  • Banned
  • #6
Most if not all charging pads depend on the source. As they can offer 5/10/15w of power
djp
djp
djp
Idaho
  • Thread starter
  • Banned
  • #7
Jim Walter
Athens Ga
2015 JKU
hate that you cannot plug in a USB Hub. Mine tells me it wont support it.
psychlops
psychlops
New Jersey
2022 Badlands Sasquatch
Haven't tested the output, but I have a manual transmission and wireless charging. That said, I avoid using it. It seems to just heat up my phone and give it no charge. When I actually need a charge, I plug it into the USB-C port.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
I have a 2 door stick lux with the charging pad. The usb-c charges at a significantly higher rate. On par with high wattage power bricks for apple iPads and Macs. As others have said wireless charging is pretty iffy, and if you do get it to charge at a high rate it heats your battery up a lot and thus decreases life.
Shayadan
Portland
BB SAS A51
New member here! It only took over 2 years to get my Bronco.
Did a couple of measurements with a USB meter on the lower center console and on ports behind center console at the rear seats, and my Samsung Galaxy S21. Quick charge enabled on the phone with about 50% battery - no quick charge on the USB ports!
Measured USB type A and type C with a few different cables with repeated results.
USB type A charging current 1.39A @ 5V
USB type C charging current 1.79A @ 5V
Hope this helps others!
Ford Bronco USB output wattage (anyone tested?) 20220920_204949
Ford Bronco USB output wattage (anyone tested?) 20220920_205137
Ford Bronco USB output wattage (anyone tested?) 20220920_205748
Ford Bronco USB output wattage (anyone tested?) 20220920_205837
djp
djp
djp
Idaho
Thank you, this confirms C is slightly stronger amperage, and i will use that port for my setup
sko
Tomasz
Denver,co
elantra, have dep on a badlands
Most usb inputs in vehicles are for connectivity to the head unit, they're not designed for charging. I see ppl come into my store all the time, they plug in a phone and use it for maps all day long, they get a charging icon but the battery is slowly discharging instead. I recommend a cigarette lighter insert, look for any qualcomm enable 3.0 or 4.0 one, samsung licenses their quick charge tech from them and it also helps out iphones with higher wattage. Depending on which samsung you're running there's a 45 watt samsung car charger that enables super fast charging. If they're out of stock online go to your closest tmobile store; or call. They have them as a car/home bundle with 2 extra cables for $60.
https://www.samsung.com/us/mobile/m...es/45w-dual-car-charger-black-ep-l5300xbegus/
