Upfitter switches solved
DrillRX
Bakersfield, Ca
2024 Ford Bronco BB SAS 2 Door 6 speed
Greetings from a new user, and first post. Thought I’d share a solution I’ve found for Upfitter switches without going to the dealer, and worrying about changing out fuse panels and such.
A company called SDHQ Motorsport has a replacement mount that replaces the sunglasses holder, and utilizes the Switch Pro’s 8 or 12 switch panel. It looks VERY factory from the looks of it. The Switch pros system is also infinitely programmable.
They also have a “hidden” mount for the Switch Pro power module for either system.
Ford Bronco Upfitter switches solved IMG_1158
Ford Bronco Upfitter switches solved IMG_1159
Golfsnob
St Augustine
2023 Base 2 Door, Manual, 2.3
Nice. I ordered my 2020 base (which ended up being a MY2023) with the upfitter switches as the only option and didn't even get that. My local shop set me up with a rebranded switch that mounts to the grab handle. I would have preferred the factory switches but it works.
Ford Bronco Upfitter switches solved IMG_1837 6
Ford Bronco Upfitter switches solved IMG_1838 8
Ford Bronco Upfitter switches solved IMG_1839 6
Oly_Bronco
WA
Oldhippie
Barry
Santa Cruz, Calif.
Ford Bronco Upfitter switches solved IMG_3062
Made my own switch box/switch setup…but now need a couple more…
