Uneven Front Hardtop Panels
PorpoiseBlue
Mercedes, TX
Ram 1500 Laramine
Curious to know how other's front panels fit on their Bronco. Is it normal for there to be some unevenness or are they meant to be completely flat?
Ford Bronco Uneven Front Hardtop Panels PXL_20240509_204026106
Ford Bronco Uneven Front Hardtop Panels PXL_20240509_204041345
Ford Bronco Uneven Front Hardtop Panels PXL_20240509_204151351
BeachTiger
South Carolina
2019 Ford F150, 2022 Bronco Badlands
There are a few threads on this if you use search. They will probably mention TSB 22-2288. Just Google that.
Jruta
Nj
A51 Bronco 2 door
My 22 is the same. I always just assumed it was normal
2023bronco
location
vehicles
Sweet, I have the same issue. Plus, part of the weatherstrip is popped up.
And the damn rear cap is cracking under the window, which is warrantable.
Hmm, the TSB is 2021-2022. Not clear why it's limited.
Jruta
Nj
A51 Bronco 2 door
Knock on wood, I’ve never had a single drop of water leak and I’ve taken the front tops off dozens of times, so I guess I’ll consider myself fortunate and keep truck’n until I replace it with a soft top someday.
DesertMike680
Las Vegas
Take it to your dealership. My MIC got replaced the beginning of March for that and the "honeycomb" issue.
Onestepmore
Amos
Ballwin, MO
2023 Ford Bronco Badlands with Sasquatch
My 2023 2 door Badlands is the same...uneven... so I too assumed it's normal too!
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
You can easily adjust the latch points to fix this. You need to pull down the overhead console to get access to the latch plate bolts. They adjust up/down.
jrollo7
James
NY
Range Rover Sport
same for my 2023 BD. No water or sound issues.
