UCA won't release ball joint
Mad Max
James
Southern Utah
2024 Bronco
Thought I'd install perch collars today on my 24 BL Sas but I can't seem to get the control arm to release the ball joint. Been whacking it pretty hard, both hanging free and on the jack stand. The book shows a special tool, 204-592. Before I go there does anyone have any tips.? Much appreciated.
I'm guessing the knuckle is going to be worse...
I couldn’t get mine out either. I ended up just going to the LCAs instead (was doing suspension so needed to get aligned anyway), but thought real hard about getting a joint puller
Mad Max
Mad Max
James
Southern Utah
2024 Bronco
thx. I'll let it soak in WD-40 for a while first. Probably will need a puller
Roadbronc
Jerry
Northern ME
2005 Toyota Echo, 2014 Ford Mustang GT
Just take a BFH (big f*** hammer) and give it a smack. It takes quite a big smack to release it, but it will go. You need a decent size hammer like a 5 lb. sledge.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Mad Max
Mad Max
James
Southern Utah
2024 Bronco
I got it. WD-40 overnight and a violent swing with the 2-1/2 lb hammer. Thanks to all for the tips. Curiously the axle wasn't stuck at all. :)
Probably saw what you did to the poor ball joint and decided to cooperate
DewarT
Todd
I just added collars a week or so ago. I marked the cam bolts for position on the lower arms and pulled those two bolts. No worry about pulling the axle apart and didnt need to touch the ball joints.
Mad Max
Mad Max
James
Southern Utah
2024 Bronco
A little follow-up. Don't mash the brake with the caliper off. I was wanting to turn to full lock to make some room. Muscle memory took over when I jumped in to turn the wheel. Blew up the caliper and got about a gallon of brake fluid on the floor. Rookie mistake.
