- ORACLE
- Mar 13, 2020
- 25
- 756
- 2,175
- New Orleans, LA
- Website
- oraclelights.com
- Bronco
- Undecided
The first and only plug-and-play solid-state Bluetooth-enabled relay available! Our device is compact and waterproof, the TRIGGER ONE Bluetooth Solid State Relay handles up to 30 amps of current. The TRIGGER ONE works in new or existing installations to add wireless control as well as dimming and flashing to the attached accessory. Control existing vehicle light installations with either an iOS or Android mobile phone. This high-tech feature is a perfect way to keep your lights from draining your battery or other electronics to be ready when you are! Turn on a radio system from outside of the vehicle, add it to a trailer light circuit to activate an outside light from the grill or campfire, or connect it to your lights.
In addition to turning circuits on and off, the app allows activation of a flashing mode or brightness control of connected lighting.
https://www.oraclelights.com/products/trigger-one-bluetooth-solid-state-relay
- Built-In Bluetooth Connectivity
- Plugs into standard relay
- Controlled via free TRIGGER ACS PLUS
- Wireless dimming and flashing control
- Controls lights, radio system, etc.
- Activates flashing mode or brightness control
