Trouble removing beauty rings
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
Lifeliberty
Moonbeam👀
Columbus, OH
I agree. I have one that I'm not exactly itching to use but it's in my toolbox..
Definitely a tool of last resort.
I never know which direction they are going but it always works hahaha.
It's on my wish list right now, my last one got beaten to hell :ROFLMAO:
They are great for when you are fed up and pissed and want to beat on something
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Impact driver. Only way to remove set screws from rotors, should work here no?
69BroncoX302
1969 U15, 2021 First Edition
You gotta hit it with your purse mate, JK. But really, that is a bit concerning that the level of effort that is being utilized and nothing is budging.
marcacier
Marc
Montreal, Canada
Explorer ST 2020
That’s what I was using. I made it through 4 tires without a breaker bar but the last two bolts on the passenger rear are ON there.
Use an impact wrench with a T45 bit.
Use a hammer and bang in the T45 bit in the TP40 fitting and then connect your impact wrench and she will come right out!
Hi guys mabe this information will help you
fschael
Federico
Houston, Tx
2002 F-150 Supercrew FX4
Snydermann
Tim
South East, PA
Samurai, VW Thing, MINI, smart, Astro Van
MillerAndCheeto
Robin
Calgary, AB
fschael
Federico
Houston, Tx
Thanks for the information!
I was confused as well and I bought both to remove mine. I didn't have any issues with the regular one.
Lifeliberty
Moonbeam👀
Columbus, OH
Has anyone ran into problems removing the bolts that hold the beauty ring? I changed 4/5 to a darker color and the last one I attempted had two bolts that would not break. I’m worried I’m on the verge of stripping it. Any suggestions?
What's the update? I need the answer to one of life's most aggravating experiences
If you still can't get it then last hope is take to a machine shop
What sucks is that you buy new vehicles so you don't have to deal with frozen bolts:ROFLMAO:
But that's the way it goes. I see it as a challenge
fschael
Federico
Houston, Tx
Hi here is a video of a guy that uses the T plus Tork bits
I understand but there is thread that also says 45 torx and having both for mine, the one that helped me was the regular one.
fschael
Federico
Houston, Tx
This is what I bought and was perfect match. Didn't have any issue :)
Ford Bronco Trouble removing beauty rings 22E6CAC1-1683-409F-94D9-00EF840DB708
