Trigger 4 Plus wiring question.
Denis85
New York
2025 Bronco
So I purchased a Trigger 4 for my outer banks. Looking at it now and there’s a Yellow “trigger” wire along with a positive and negative. It says to connect it to a switched source to keep it from staying energized all the time.
For anyone that has used one, or something similar, what did you wire it to? Something in the fuse box? Tap a wire under the hood somewhere? Thanks!
Ford Bronco Trigger 4 Plus wiring question. IMG_2169
Ford Bronco Trigger 4 Plus wiring question. IMG_2170
Ford Bronco Trigger 4 Plus wiring question. IMG_2171
Most folks will run an add-a-tap to the fuse box. I used the 360 Camera fuse under the hood for my setup (#22).
Denis85
Denis85
New York
2025 Bronco
Most folks will run an add-a-tap to the fuse box. I used the 360 Camera fuse under the hood for my setup.
Got ya! I’ve never actually used one. The idea makes sense though.
Denis85
Denis85
New York
2025 Bronco
Haha thanks again
Denis85
Denis85
New York
2025 Bronco
Denis85
Denis85
New York
2025 Bronco
Actually, I have another question since I'm obviously a newb at electrical. I'm going to be running 2 Baja Designs Squadron Sport ditch lights. Please correct me if I'm wrong. According to Baja Designs they draw 26 watts each, so that's a total of 52 watts. Divided that by 12.5 and got 4.16 amps. Their documentation says 2amps each. Is it as simple as 2+2=4?
So, is it safe to assume that the 10-amp location on the switch box would be fine to run 2 lights? I have the option for 10 or 30 amps.
Yup
Baja Designs
San Marcos
10-amp channel would work no problem!
Best,
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
