- Phil
- Jul 21, 2020
- 45
- 4,827
- 16,004
- IN
- Website
- www.ruxerparts.com
- Fords
- Badlands
Valid point and glad you brought it up. There is definitely some rotational drag through the CVs, front diff, front drive shaft and through the transfer case. The reasoning they may have done it like this is consolidating the engagement points to the clutch pack in the advanced 4x4 and blocking gear in the part time. You eliminate the need for locking hubs (which have been problematic for Ford in the past), manual hubs which require you to physically engage them and in the case of the advanced, no need for a front axle shift motor/fork/locking ring to put power to the front axles. All of these add weight and expense and maybe they figured out the setup they're using now is more cost and weight effective than one of the other methods.What I want to know is why the transfer case is not disconnected from the front driveshaft and axle when in 2WD? The front end spins- including differential, driveshaft, axle gears, half shafts, etc. when in 2WD. The transfer case is not transmitting any power, it all spins freely but creates drag.
Are all Ford trucks like this (Except F250, see below)? My past 2019 Silverado the transfer case disconnected the front driveshaft and axle so there was not that extra drag of the driveshaft and the main gears, at least. The half shafts still spun though. At least minimized some of the drag.
I was really surprised (and disappointed) that the front axle, etc. is always engaged.
Locking hubs are what is needed to completely disengage the front end when in 2WD. Ford has them on the F250's- why on them and not the Bronco?
Maybe my gripe is why not just put the M210 in everything along with the advanced transfer case? You could still up charge for front locker like SAS and BL, lower the number of service parts, it's at least serviceable compared to the 190 and would eliminate the front axle engagement motor on the part time setup. It would still be possible to "dumb down" the transfer case to offer 2H, 4H, 4L on part time with no need for all of the other inputs to make 4A or some of the other traction assist work. There might be a little more input cost to the vehicle but you cut down on a lot of part combos for the entire model, are able to upcharge for a few extra options and leave the door open for end user upgrades down the road. I dunno, not on the inside or know what their costs are but this just makes sense to me.
