Transfer Case Output Shaft Seal Leak
Happytown
Ryan
Zachary, Louisiana
2013 F150 Eco SCREW 4WD
I noticed the leak several weeks ago at 24k miles. No idea how long its been leaking but I was concerned enough to buy fluid and pumped a little into the t-case. Apparently a very slow leak or it had JUST started, only took maybe an ounce to overflow. I’m just going to monitor and fill until I can afford to be without it for a trip to the dealer. I think the right fluid was Mercon LV ATF for our transfer case
MWILD
Central North Carolina
2021 Base/2DR/2.3/MT & 2023 Model S Plaid
22K on my 2022 and mine is leaking as well. Might have been leaking for quite a while...anyway, bringing it to the dealer next week.
Ford Bronco Transfer Case Output Shaft Seal Leak bronco tcase
JHawk
Ray
Heartland, USA
Fusion Sport
I dropped my '23 off at the dealer today to have this same issue repaired. I have had it one year next week. Thanks for the pics that helped me verify what I thought the issue was.
swooshdave
Portland, Oregon
Mustang
I'm about to do the same thing. Coming up on a year and 19k miles.
myrealname123
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
Anyone else put significant miles on after replacement? I'm over 38,000 miles now and have not had any further issues, thankfully.
The Beaz
Shad
San Francisco
Mine was replaced around 6k miles, I'm now at 37k, it has not leaked again. Just checked over the weekend.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning! I would be glad to help you out with shaft seal leak concerns. If you are still in need of assistance, just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
  • Like
Reactions: 0ne
swooshdave
Portland, Oregon
Mustang
Damerow Ford in Beaverton, Oregon is actually one of the better dealers in the area and I'm scheduled to have them look at it tomorrow. Thank you for your offer.
One more upgrade
Joe Mogush
22 Tesla Plaid X 22 Escalade
Ford Motor Company took care of me on a warranty issue; I would definitely reach out to them. The customer service was great and they went above and beyond to make sure I was satisfied.
broadicustomworks
Hanging Rock, North Carolina
I’ll join this club.
46.6k miles and just noticed it tonight when I went to drain and change the T-Case fluid.
No need now, will get it fixed and then do it.
Ford Bronco Transfer Case Output Shaft Seal Leak IMG_0562
K2Bronco2021
Keith
Thousand Oaks, Ca
2002 Explorer, 1995 Mustang GT
2022 OBX. Build Dec 2021. Just found a couple of drops of fluid on garage floor and after a Quick Look appears I have a leak as well. seems to be coming from bottom bolt.? Everything else looks clean.
Ford Bronco Transfer Case Output Shaft Seal Leak IMG_3627
Ford Bronco Transfer Case Output Shaft Seal Leak IMG_3626
0ne
Nate
CO
Flex
Give er a couple ugga duggas and maybe it seals back up? 🤷‍♂️ Edit: what kinda bolt head is that, reverse torx??
okbob
North of the Red
71' u15, 66' u14, 66' u14
Add me to the list, 41k miles.
  • Sad
Reactions: 0ne
Ford Motor Company
Dearborn
Good morning! I would be glad to help you out with this transfer case shaft leak concern should you need further assistance. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
