CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRD
you can also get one for 2 doors. Some things are wayyy overpriced
Can you send a link for a 2 door from Hooke, I don't see anything but a 4 door from them?
mjcutri
M
Upstate SC
2023 Bronco HE
Tooold
Guy
Here
65 FB, transit awd duel sider, flex 3.5L, BaseManS
@TrailRax Can you help me understand the full and half rack's load ratings when not using the "optional Pak Rak"?
I am only able to locate the fallowing info on your rack system "
  • Static load rating for half-rack: 300 lbs evenly distributed across the rack
  • Dynamic load rating for half-rack: 150 lbs evenly distributed across the rack
  • These ratings are rated and measured WITH optioned Pak Rax. The Pak Rax allows for the distribution of weight to the body of the Bronco allowing the best stability and carrying load capacity".
I don't plan on using the "pak rak" and would like to know the dynamic and static ratings of both the full rack and half rack so I can decide what will work for my application. Thank you for helping me understand.
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
Ford rates their Hardtop weight load as 110 lb dynamic and 450 lb static. So without the pak rax, for us to rate the rack above the Ford specified rating would be false per Ford's weight load ratings. While we are confident our rack by itself (without pak rax) is capable of taking on the specified 300 lbs static and 150 dynamic for the half rack mentioned above, we still want to stay within the specified rating for Ford Bronco.
So like the bottom paragraph exclaims in all of our Bronco Roof Rack line, weight load limit without Pak Rax is generally what Ford recommends considering you are putting all the weight into the fiberglass of the top and any weight over their recommendations is by user discretion. With our pak rax, we are able to distribute weight to the body of the vehicle allowing us to have a verified load rating increase via CAD software testing and real life testing (you can see it done on our instagram).
Hopefully this answers some questions. While it is tough to give you a solid answer because of Ford's limitations, we are confident our rack is capable of taking on the weight load ratings we specify on our site without pak rax but overloading Ford's recommendations is at the users discretion.
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
@Rusty Sheckelford I’m adding a video showing me giving the Bronco a good shake while holding on to the half rack. I’m thinking it would work as a lift point to take the rear top off. Your decision, but I’ll probably do it when I get to taking the top off.
Snowing this morning so I ordered a Kuat Grip 6 ski rack. I’ll post photos when I get it installed.
Solid install!
Tooold
Guy
Here
Thank you for helping me understand better.
Johnko
Knoxville
Bronco Sport (in the market for Badsquatch 2 door)
Does the roof come off the same? Rack just stays attached ?
Mtea
Mtea
Marty
Idaho
2023 2dr 2.3 Auto, Porsche Cayenne Diesel Platinum
@Johnko I would think the roof would come off the same but I have not had my roof off. I was even thinking of attaching a hoist system to the rack in the case I take it off. I don’t have the racks that cover the side windows in the back so I don’t know what impact that would have. @TrailRax what do you say?
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
The rack without the Pak Rax can stay on when you remove the hardtop but if you have the Pak Rax, you will need to unbolt the Pak Rax.
Johnko
Knoxville
Great I figured as much, I'm looking for a rack that will allow for the hard top to come off without any extra work.
Also, I could not find the dimensions anywhere online for the half rack. What is the length? I have a 66L Rugged Roam case and 31in length, just wondering if that will be no issues fitting on this rack.
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
4 Door half rack: 33" x 48"
2 door half rack: 44" x 48"
Let us know if you have anymore questions.
