Trailer hitch wiring
Clean68
1968 Ford Bronco, 2008 Triumph Thuxton
iwantabasebronco
No ones business
gmc
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
Clean68
Clean68
iwantabasebronco
No ones business
gmc
They do? If I dont have the factory wiring what does it connect to?
I think it comes with wiring harnesses to clip into the tail light wiring then it requires a 12v positive that runs up to the battery
https://www.curtmfg.com/part/56468
also: it’s a 4 pin so if you need a 7 pin you might be out of luck for now
mmorgan
South Carolina
2023 Bronco
Firefight911
Phil
P52Ranch
Oklahoma
2DR 7MT Badlands, F150 Lightning, New Holland 4030
I wonder if the Curt wiring harness works the same for the regular taillights and the LED taillights? I would have concerns on the LED taillights and that harness.
Clean68
Clean68
Not having trailer brakes might be an issue. I’ll be doing mountain roads. Does the ford 7pin work if installed after the build?
Clean68
Clean68
Do any of you know if I need a drop down hitch? With the Sasquatch package? Also I should have no issue with a 6x12 trailer right? I’ll be towing a uhaul trailer.
Ordered the hitch from summit racing for $111 free shipping and the wiring from e trailer. All in for everything was only $200
Lastly, think this can be wired to work?
Tekonsha Prodigy RF wireless brake controller
https://www.google.com/search?q=Tek...troller&ie=UTF-8&oe=UTF-8&hl=en&client=safari
skoorb76
Junk
My understanding with those is that the only extra wire you should need is the constant hot to feed into the wireless controller.
I think if you start with the 4-pin plug and play, there is a 4-way to 7-way converter cable that plugs into the 4-way with an extra pigtail to add the brake signal, constant hot, and reverse. just need the constant hot if you can get away with no reverse on the trailer. then that plug into the wireless controller. This is what I would plan to do if I needed brakes... I don't at the moment and haven't done this, but have looked into it. https://www.etrailer.com/question-274209.html
Constant hot should be easy, but reverse seems elusive.
UberGadgetFreak
Mt. Holly, NC
21 FE Bronco 22 FE Mav, 23 Mav Tremor, 03 Marauder
Revisiting this thread since I just installed mine.
Ford Tow hitch, but used the Curt kit. Modified to use the Ford 4-way so it mounts to the hitch like it should.
However, in the Curt instructions, it doesn't say to actually connect the black power wire in the steps (1-10):
56468_INS.pdf (curtmfg.com)
But it is shown on the last page. Does this need to be wired up? Mine isn't wired up yet and it seems to work fine.
Clean68
Clean68
I got the same system, installed 2 days ago. I called and they said it must be installed.
dgorsett
colorado
F250, Mustang, Explorer
Interesting...keep us posted...maybe just with the LED's? I've got the Curt kit and it would be awesome not to have to bring 12v
