Trailer hitch recommendations
JBradleyD
JBradleyD
Bradley
You could also use a different spare tire relo bracket and mount it offset (ie shifted to the passenger side) and that would open up center clearance for a higher hitch mount setting.
Unrelated note - secure that leveler jack handle up parallel, they tend to catch things and go “snap” hanging down like that, especially on steep driveways and trails.
I like that spare tire relocation. It's much more practical for towing, and it looks like the bumper is carrying the weight, not the door.
The picture is a few months old. I have swapped those handles for a modified bolt with a 3/4" head so I can use my drill to run the jacks up and down. Nothing left to drop down, but thanks for the heads up.
Ford Bronco Trailer hitch recommendations IMG_8861
B22-2023
Houston
I run that particular spare carrier (from JCR), yes it’s totally off the door but it attaches to their own Vanguard bumper. I didn’t think as to whether there is a similar option for the stock bumper you have, you’d have to research.
Good on the modified jack, same thing I do now after seeing it once on someone else’s camper and going…..huh.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Ford Bronco Trailer hitch recommendations 20250313_111004
FloridaGuy
Andy
2024 Bronco
I use a lock N Role with a 2-inch drop. It fits and is articulates well.
I was thinking of doing that, but didn’t cause of the expense in converting my trailer. Can you post a pic of it all hooked up
