Trail Sight Delete
rmb
RAV
New Jersey
2020 Lincoln Navigator
Just sharing. I ordered these trail sight deletes and, although they are not quite as snug as I would have liked, they are no more un-snug than the factory trail sights, so, if you are looking for a cleaner look, these represent a pretty good option:
BLUMAK3D Trail Sight Deletes for Ford Bronco 2021+, Enhances Visibility, Easy Install, Made in USA, 2 PCS (Black)
https://www.amazon.com/dp/B0C7RMDS2C?psc=1&ref=ppx_yo2ov_dt_b_product_details
Ford Bronco Trail Sight Delete 2023 Ford Bronco Trail Sight Delet
Classic28
Brandon
Maryland
Nissan Titan
Same ones I have, took some adjusting to get the spacing right but overall looks really good.
Buck N Bronc
Chuck
from Texas, but in Atlanta
Escape
Looks good! I had considered these before I just put the Amazon white covers on mine.
TEAMSLO
NV
youtube.com
23' Bronco 2.7 4d Oxford White (sold) & '23 Jeep 392
I'll probably get something along these lines but way down on my priority list for now...... eventually.
1st 75th ranger
jeffrey
nj
to each their own
i love mine
Dusty
Mentone, CA
70, 71 & '21 Broncos
Back when the Bronco was announced I wasn't a fan of the trailsights and I was going to make a million dollars designing and selling a trailsight delete. Of course that was just another pipe dream that never came to fruition but a funny thing happened on the way to the trailsight delete shop: I actually stopped hating the trailsights. Or, at least became indifferent to them, maybe even slightly positive. Now when I see Broncos with the deletes I think they look kind of plain, that they're missing something that makes a (6G) Bronco a Bronco.
That said, I do wish ADV or other vendors would offer versions of their fiberglass hoods without the trailsight notch. Trailsight delete might look cleaner if that rectangle was just part of the hood rather than a separate piece of black plastic.
Scoop
Gary
Cuchara, Colorado
2026 Stroppe Edition, '74, '76, & '78 Broncos
Agree. I think the trail sights are a very distinctive feature of the 6G. This is something that Jeep could never duplicate due to their front fender styling. Kind of sets us apart.
BCHBRNC22
Virginia Beach
2022 Ford Bronco
To me, the body already is a trail sight so I put the black Dee zee deletes on my carbonized gray BD. With some adjustment, look ok. Now I need some for the race red heritage. Won’t someone make color matched accessories for these things? Even if just plastic instead of aluminum would be ok with me. Maybe I can get my son’s friend to 3d print some.
PlayTime
Patrick
SoCal
'23 2dr 2.3L OBX non-SAS Eruption Green
I remember seeing on the forums a while back a delete that was actually one that could pivot back up for use as a tiedown or brush guard. That seemed pretty neat...
SilverStreak02
Andrew
KCMO
22 Bronco Raptor - 02 Lightning
I too just installed these Trailsight Deletes. I found them to be distracting and I will never use them as intended. I agree the body lines are not exotic car perfect but they are very livable.
Ford Bronco Trail Sight Delete IMG_2032
bek
Lexington, Kentucky
2023 Wildtrak
It's been about a year now... how are they holding up? Any fading or anything else going on?
skyhunter
MA
2024 2DR Bronco
Does anyone happen to know the size of the gasket used with the sight delete? Mine did not come with them but since the crash delayed the install it is past return time and no response from the maker yet.
bryan@blumak3d
blumak3d.com
93 Cobra, Z4M, K1600GT, R1300 GS
Thanks for the BluMak3D Trail Sight Delete posts!
Here are some Pro Tips-
The stock trail sight does a great job of hiding any misalignments since the hood and fenders were never intended to meet at the nose of the Bronco. The stock trail sight gasket hides even more imperfections.
When installing our deletes, any Ford factory misalignment or skew of the hood will become noticeable since your eye has a very reasonable expectation of a level plane aesthetic between the hood, deletes, and fenders.
Keep in mind that Fords (and most other brand name autos) are mass produced, and there is/always has been a lot of "slop" in panel fitment.
With or without our deletes-
If you find yourself looking at some tweak in your hood, the first thing to do is-
•Adjust the rubber hood isolators which dictate the height of the corners of the hood when closed. You can thread them in or out to raise or lower each side of the hood. That should address any height variances.
If the hood is further away from the fender on one side, you can try-
•Loosening the delete and shifting it in the mounting hole. There's just a tiny bit of play there.
If the issue is more than that-
•Your hood mounting bolts can be loosened (do this with extreme care) and the hood can be shifted to align it properly.
About the product-
As the name of the company may elude- we 3D scanned the hood, fender, and trail sight mounting areas of a new Bronco to create the BluMak3D Trail Sight Deletes. The final product is made from nylon in industrial 3D printer. (Multi Jet Fusion).
Due to the precision of the scan/design/manufacturing process, and our experience with it all, it is very rare for variation between examples or batches to be anything more than microscopic. The only part of this product that is hand assembled are the brass inserts we install for the bolts.
We are a small company of 2 deeply experienced dudes who love cars and cool stuff. We rely on the quality of our products and our reputation to keep it going.
We personally make everything in house in San Diego, lay eyes on every single part that goes out the door, and truly care about customer experience. So, if you find a flaw, defect, or any issue in any of our products, we are always here to help either through guidance, or replacement of the product.
We have other great stuff for your Bronco on our website too-
BluMak3D Bronco Products
