- Brandon
- Oct 5, 2020
- 49
- 608
- 1,501
- Utah
- Website
- www.puravidaoffroad.com
- a number of classics and my 4dr Badlands
- Badlands
You all liked my bracket design enough that I went ahead and created a bunch of them and an Ecommerce site to spread the love.
Find the bracket here - https://puravidaoffroad.com/shop/ols/products/traction-board-mount
The design goal was to have my traction boards with me at all times but unobtrusive in taking up space or impeding visibility. The boards are tucked up behind the roll bar so you'll forget they're even there until you need them. They fit within the MIC hardtop and the boards and brackets can easily be mounted with the hard top in place. The brackets and boards technically fit within the soft top as well, however, I'm not a fan of how little clearance there is between the bracket platform and the rear window of the soft top. I'd be afraid that there would be flex in the soft top, causing the to rub and cause damage over time.
These traction board brackets mount to the existing nutserts that are located on almost all 4 door Bronco roll bars. The only exception is that the very early 2021 4 dr Broncos don't have the mounting holes.
Here's a bunch of pics. Feel free to ask questions or provide feedback on improvements or new designs.
Here's a sneak peak of what I'm working on next. Making some modifications to the vertical portions of the attic tray, but my goal is to store my recovery gear up there. ARB boards will also mount underneath the attic tray, however, Maxtrax boards are a little too long to fit between the roll bar and brackets.
