Towing hitch Help!!
Suke996
Bronco First Edition (Reservation)
2023 Bronco Raptor, ATC 7x16 trailer 2400 empty weight(carrying 2 racing karts and gear so maybe 800 pounds).
Would you keep everything the same and swap to a different trailer jack with the crank on top or electric?
Or find a longer shank ball mount that extends back another 2 inches? (Only issue I have is getting the tongue weight back might be a concern???)
Ford Bronco Towing hitch Help!! 20230706_125220
DCtoobs42
Brad
1999 T4R Limited (RIP)
Two Things:
1: Support the trailer to take weight off the tongue jack, unbolt it, and turn it 180 and reinstall. At least that will get the handle on the other side.
2: Some folks use an extender to get the ball out from under the tire. I deal with the same problem. My trailer is very light so I attach the ball to the trailer first and slide it into the receiver and install the pin (which is a pain). Last option would be to find another type of low profile lock for your trailer that will fit under the tire.
Good Luck.
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
I would spin the jack around so the handle is on the other side as the above poster already mentioned.
Suke996
Suke996
That was my plan, but the damn holes don't line up once you turn it 90 degrees.
Aman
Aman
Northern NJ
It's a triangle pattern, correct? If so, can you rotate it 120 degrees in either direction and match the bolt pattern? If not, then get a side mount trailer jack.
killaz05
Anthony
Rockledge, FL
2021 Ford Bronco Badlands 2.7 Sasquatch
Ford Bronco Towing hitch Help!! IMG_4452
make sure you get a long hitch like the one on the bottom of the picture. Some use the extension but it cuts your capacity in half and didn’t feel as stable as the long hitch.
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
Why not a tongue jack that mounts farther back on one side?
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
You need a longer ball mount. It looks like you are using a 2" drop so that should be easy. i would go with a 12" or 13" mount like this:
https://www.curtmfg.com/part/45260
Suke996
Suke996
Rotate it to where you like it and just redrill the holes, simple :)
That's exactly what I just did. Only 1 hole needed to be re drilled.
Might need more of a drop on the ball mount? I'll see what it's like on the flat road.
Raptor squatted less than 1 inch (22 1/4 ball mount to 21 1/2).
Ford Bronco Towing hitch Help!! 20230706_144045
Ford Bronco Towing hitch Help!! 20230706_141527
Ford Bronco Towing hitch Help!! 20230706_144601
Pressurized
Rod
Gilbert, AZ
Test your clearances while turning...
LanceIto
Lance
Boise, Idaho
2023 Bronco Raptor
FYI i bought an extender mainly for my bike rack but it states “no intended for towing” or some thing like that.
I have been removing the spare when I tow.
2DoorDan
Dan
Pennsylvania
2022 Bronco
I bought a new jack that clamps on the side, and rotates 90 degrees so it is completely out of the way when traveling. It has the added benefit that I can open the Bronco rear door.
Also I would urge caution with long hitch drawbars. As far as I know, a 12" drawbar cuts your tongue weight capacity in exactly the same way that a 6" drawbar plus a 6" extender does. The geometry is the same, with the same leverage twisting your hitch down beyond its capacity.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
I'm considering a trailer also... could one remove the spare, put it towards the rear of the trailer or at least over the axle, to reduce tongue weight? Frees up the jack too.
