Tow package
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
I had my hitch installed at the dealer as well and I have all the trailer options except the light check. I thought I was supposed to get the light option and noticed when I picked up the truck that it wasn't there. The technician came out and reinstalled the software again, showing me while he did it and the light check still didn't come back. I guess I'm going to have to wait until I can use Forscan to get it. Oh well!
The first picture is from the app. To confirm, you aren't seeing this?
Are you seeing the second picture once you go into the Features option on the infotainment screen?
The third picture is what you see once you select "Towing".
If you can see what is in the second and third pictures, then the vehicle has been programmed and it is aware that it has the towing option, and the problem is with the app.
Ford Bronco Tow package Trailer option a
Ford Bronco Tow package Trailer feature 1
Ford Bronco Tow package Trailer feature 2
VirginiaHeritage
Frank
‘25 Bronco HE
I have a ‘25 and had the OEM tow hitch on the window sticker. Dealer had an outside tech install it a couple of weeks after I took delivery in April.
I have the trailer light check option on the app as well as the Towing menu in the infotainment display.
The latest iOS 26 version of the app just says “Ford” by the way. They dropped the “Pass” from the name.
Ford Bronco Tow package IMG_3842
Ford Bronco Tow package IMG_3843
OutdoorEngineer
Kurt
Kansas
2024 Bronco, 73 Bronco
GoHawks63
George
Metro Detroit
totaljustice
Kevin
Middle Sackvegas, NS
My infotainment Tow Screen appears like yours but I don't get the trailer light check in the app. My brother's '22 Outer Banks shows this.
Ford Bronco Tow package towing
GoHawks63
George
Metro Detroit
Interesting. Would be interested if others have the light check on the instrument panel. I suppose it's possible that there may have been changes to the firmware where it's no longer visible on the infotainment screen if it's on the app.
I don't have an explanation for that. However it does seem that they have enabled the tow features on your Bronco otherwise you wouldn't see them on the screen.
Obvious, but I'll ask anyway. I assume you've created an account on the Ford app and it is connected to your vehicle by VIN.
Huckelberry
Richard
Central Virginia
2024 Badlands Sasquatch, 2003 Toyota Tacoma TRD Offroad
Can the module be ordered separately, or does it have to be purchased in the kit?
totaljustice
Kevin
Yes, I had the Ford Pass app that was changed to just Ford recently. The only difference I can see is that you have an Apple device while mine is Android, so I'm wondering if there's something about Android or Samsung that will prevents it from working with my version.
totaljustice
Kevin
Unfortunately, I can't answer that for you but there are others here thay work for Ford such as @Ducati1098 that may chime in with that answer.
Oly_Bronco
WA
Does the trailer light check option only show on the app when a trailer is connected?
GoHawks63
George
Metro Detroit
No. It is always there.
As for it showing up on the infotainment screen, I wondered if it would only show up if the vehicle recognized a trailer was attached, so I went out and connected a trailer we have here at work to my Bronco. I did get a dash message stating that the truck recognized a trailer connection and took me to the towing screen, but the trailer light testing option wasn't there.
I was able to do the trailer light test from the app, and I also was able to confirm that the rear parking sensors and cross traffic alerts were off when I put the vehicle in reverse.
Ducati1098
Maybe. But I would need the engineering number off of a 25 module to see.
Oly_Bronco
WA
Interesting my 23 Bronco Black Diamond shows it on the infotainment but not on the app.
VirginiaHeritage
Frank
‘25 Bronco HE
Nope, all the time. I haven’t even put a ball on mine yet.
HighVelocity
Big Sky Country
Pinto
Just make sure you change the air in the tires before hooking up the 5th wheel to it.
