Torque Wrench recommendations?
da_jokker
Jeep Wrangler JKUR
For me, it’ll be lug nuts and such.
Big things like this, I would suggest the harbor freight but I'm biased. For under $25 you can do lug nuts all day long. And in the 80-100 pound range is where I trust it the most (it's the lower ranges like 10-30 I worry about)
One thing to remember, accuracy isn't as important as consistency.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Ground_zero298
Scs michigan
Running all capri here. No issues. Not expensive. Thinks it’s around $130 for the big 1/2”. They make some damn good sockets and t star bits too. Switched over to their brand 3 years ago. Have yet to strip or break anything and I’m all about breaking stuff.
No matter what you get, make sure you back it off for storage.
BroncoAZ
Mitch
I like the Precision Instruments split beam torque wrenches, but I paid about 60% of the current cost. They are great because they are very fast to adjust and you don’t have to dial them down when stored. Tekton came out with a similar design for about $100.
https://www.amazon.com/Precision-In...495&sprefix=dial+torque+wrench,aps,89&sr=8-39
Tekton
https://www.amazon.com/TEKTON-Torqu...lja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1
Maybe it's just me, but my torque wrench that I've had for 20 years came from harbor freight. I've used on everything that needed to be torque (with the exception of very light lbs).
Ironically, The thing I've used it the most on is lug nuts...been doing it for years. Recently used it to put my valve train back together on my Jeep.
One thing to keep in mind, they always say they don't make things like they used to. With harbor freight, it was always China-made So I don't know if it's possible For The quality to get worse :)
https://www.harborfreight.com/hand-tools/sockets-ratchets/torque-wrenches.html
(Pretty sure I have just a normal Pittsburgh)
I’ve seen the $10 Harbor Freight cheapo torque wrenches made in Taiwan and China. I bought a few of the Taiwan ones for a secondary tool set, they have been great.
JustinZ
Justin
Chesapeake, VA
'22 Badlands
Whatever you get, set it back to STOP or however it is marked at the bottom of the scale. Don't leave it on 120 lb/ft and put it away. They stay calibrated MUCH longer when you treat them right.
BroncoAZ
Mitch
The split beam that I posted are tolerant of improper storage. I still turn them down out of habit.
helifino16
Ron
Mount Sinai, NY (Long Island)
I agree here. For occasional use (lugs and the occasional bolt-on), I’d rather not spend big $$$ like a mechanic. They need that kind of long lasting quality. Some thing is better than nothing (unless you have a calibrated firearm - like @C00TER). Harbor Freight / Pittsburg is fine if you take care of them.
da_jokker
Jeep Wrangler JKUR
Exactly. I always store mine backed off, and I've always made sure to never drop it or bang it against anything.
Like I said been going stong for 15-20 years and still use it every time I pull a tire off at a minimum.
C00TER
Christian
Tonopah
Torque to yield…
RHeinz
Ric
Houston, TX
I quit using my Craftsman TW after I broke off a wheel stud.
Bought this but have not used it yet:
Ford Bronco Torque Wrench recommendations? 84875818-8E95-421E-A2AA-EA547BD246B4
Anyone have experience using one of these?
