Toplift vs. Ceiling mount hard top removal
AzureBronco23
Omaha NE
2023 Bronco
Looking for a solution to remove my 4 door hard top when I don't have any help and have to remove it by myself. Looking for opinions/experience for "Toplift" type of solution vs. "Smarter Home" type of ceiling mount. I have 10' garage ceiling so have enough room for ceiling mount but could see top lift might be easier/faster to use. Also would like to hear if there is a specific brand/model you like/dislike.
AzGrayHeritage
Keevan
Georgia
Azure Gray Heritage 24
I picked up a toplift pro V2. My feedback, get the Rockworkx replacement screws, the toplift pro is harder to put together than to use. It's been rock solid for me, off in about 10 min, on in about 13-15. Hardest part for me is backing into the garage to take it off and on cause my drive way is slanted.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
I have the Harken Hoist for Bronco/Jeep tops. It works flawlessly and I use it to remove and re-install the top on my own. I have a pretty small garage, so I have one part of the ceiling for storage and the other part of the ceiling for the Bronco top. I back in, bring down the hoist, loosen the hardware and lift. The 6:1 pulley ratio means it's incredibly easy to lift with one hand. When re-installing, I just use one hand to lower it, and a second hand to guide the top into the exact correct position. Too simple.
I've attached a picture.
Ford Bronco Toplift vs. Ceiling mount hard top removal PXL_20230519_234405553
OmahaKevin
Kevin
Omaha
2012 Mustang GT, 2023 OBX
I concur with @AzGrayHeritage. I've had a Toplift Pro since I got my Bronco and also added the Rockworx bolts. Super easy off and on. I just roll the top to the front of the garage when it's off.
tock13
Tony
WA State
Mazda, 66 Honda CT90, ‘94 Toyota Xtra cab
I think it comes down to how much room you have. The Toplift is super simple and fast to use. Regardless of removal method,, taking out the bolts is the time consuming part, even with the quick release screws. Lifiting the top off is super fast and easy with the Toplift....no brackets or hoisting or really thinking about it much.
I have a large shop so storing the top on the Toplift is no issue at all since I can just roll it out of the way if need be, but if space is tight it might be an issue. Say its pouring rain or blowing snow out and you want to remove the top and work on your truck without moving it outside, if space is tight in the garage then a ceiling hoist is the way to go in my opinion.
Sojourner
Southern Maryland
2024 Bronco Badlands
Love my Toplift. And the Rockworks roof screw/bolt kits.
Tankers
Rod
Semmes, AL
2024 Badlands, 2022 Rubicon 4xe
I have a Roll-n-jack. It works great. You can only get them from Amazon now, as far as I know
Onestepmore
Amos
Ballwin, MO
2023 Ford Bronco Badlands with Sasquatch
I got everything from Harbor freight...well except the boards and square channel to support the winch along with the 4 inch bathroom toilet flange I used for the ceiling guide.. Works Great with the remote and i can do everything by myself. I like that it doesn't take any room up in my garage...just a thought...Amos
Ford Bronco Toplift vs. Ceiling mount hard top removal IMG_2668
Ford Bronco Toplift vs. Ceiling mount hard top removal IMG_2667
Ford Bronco Toplift vs. Ceiling mount hard top removal IMG_2669
Ford Bronco Toplift vs. Ceiling mount hard top removal IMG_2670
Nc211
Washington DC
MayhemMike
Mercury
I have used both methods. The Top lift advantage is it can be removed and installed by my senior citizen self without issue. The ceiling hung electric hoist with straps advantage is less expensive and leaves garage space available..
Ford Bronco Toplift vs. Ceiling mount hard top removal IMG_1671
Ford Bronco Toplift vs. Ceiling mount hard top removal IMG_1060
Mjasi3
Chicago
I got a roll n jack. Floor based crank lift. Love it. Got a Milwaukee torque wrench. Easy bolt unbolt.
Anvilair1973
Tampa Florida
2024 Outer Banks - 2026 Badlands 2 door (wife's) and 1994 Mustang GT
I have both but I find myself almost always using the Toplift Pro. It is so easy to just wheel the top away and I can still nose my wife's car into the garage with the top over her hood.
BUCKIN6VA
Northern VA
www.youtube.com
'12 911 GTS, '25 Model X
I would for sure use the ceiling lift if I had the room for it. TopLift is GREAT if you don't have the ceiling room, but the TopLift + Roof itself takes up a lot of space in my garage.
Footer
2023 Bronco
Another vote for the Toplift !
