To keep or not keep is the question. (decal)
Keep or take off
  • Total voters
    48
crzyhawk
Virgina
2024 Bronco, 2008 Mustang
It was pretty easy to get my Big Bend stickers off. I used a heat gun though I am not certain I needed it
helifino16
Ron
Mount Sinai, NY (Long Island)
How hard was it to pull the Badlands sticker off. I have an OBX and want to pull them off but I’m afraid of pulling the paint. I was thinking if I parked it in the sun it would warm the adhesive and make it easier to pull. I want to replace it with block script BRONCO.
They come off pretty easily. I just picked at a corner with my fingernail and slowly peeled it away. There was a video online from TC Customs in Atlanta showing just how easy this was.
Leaving in the Sun for a bit is a good idea - a heat gun or even hair dryer (she will love that!) will also do the trick. Go slow, be patient. You may even be able to relocate it elsewhere - kind of an easter egg for others to find. Mine went on the Tailgate (inside) and under the top of the Center Console Cover. There's a little triangle indention on the body (near the rocker panel) just inside the door - it may fit there also.
Ford Bronco To keep or not keep is the question. (decal) Apr28-edit
not on the rug
NJ
2024 Wildtrak. 2011 BMW X5M. 2024 Nissan Pathfinder Platinum
Strip them all off immediately. What is the Bronco community's obsession with gaudy decals and stickers?
20Bronco21
Amidst the Cornfields of Illinois
‘23 Balands ‘24 Bronco Raptor
If they have been there a few years, yes, let it sit in the sun to warm up and pull at a diagonal. Pull easy. Clean with alcohol.
Eldowerks
Minnesota
Bronco ‘24
Nice retro 2G Bronco block letter script!
I warmed up the badge with a heat gun and used a plastic razor blade to lift up a corner, then it pops off pretty easy and can be reused.
Ford Bronco To keep or not keep is the question. (decal) 1781721289434-py
Agree that a badge and the 1G Bronco script is too much on the fender, so relocated the badge to the rear side window.
Xterra2Bronco
Jonathan
Southern NJ
I often ask that same question. It is like, lets see how gaudy I can make this think look with colored plastic covers on everything and stickers. I mean I think people know it is a Bronco by the front grill lettering, the bronco on the back, and tire covers. It is like the ricers that add HONDA all over everything or whatever else they put on their rice rockets.
not on the rug
NJ
It's really sad. 90% of the Broncos I see in person or on this forum are filled and covered with cheap chinese plastic crap that just looks awful. Color matching nuts and bolts and caps and covers. Color matched trim rings. 74 different Bronco stickers and decals. It's awful. Amazon/AutoZone garbage
