Tires
Brizzo1432
Jeremy
Denver
Trailblazer ss
Does anyone know what size tires you can put on a base model without having to make any modifications? My original bronco I ordered was deleted out of the dealships system so all my specs were deleted and now I have a base model coming. I’m trying to see what I can do to make my base model look a little more attractive.
GoobertownDaddy
Murphy
Arkansas
2018 F150, 2004 JEEP WRANGLER, 2022 Bronco OBX
A lot of people are putting 285/75...
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
If I had a base model coming, I would look to buy some takeoffs off of a big bend or black diamond. That will get you 17-in wheels and better tires for a lot less than buying new wheels and tires.
Brizzo1432
Jeremy
Denver
Trailblazer ss
Good call, I’ll have to look into that. Are those readily available?
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
Search engine...or just head over to the marketplace section of the forum. My wife's base got some takeoffs from here off of a donor BD. Definitely, the way to go.
Bscholl8
B
Austin
2021 Oxford White Bronco
285/75 R16 is the biggest you can put on the base wheels. So I was told at the Discount Tire I went to. Pics for you to see what it looks like. 2in leveling kit as well.
Ford Bronco Tires 22D75142-0FB6-4DAA-B210-4EA7D7721795
Ford Bronco Tires FEB62482-17B7-442F-8A77-F4F0CB79E7A8
Brizzo1432
Jeremy
Denver
Trailblazer ss
Thanks for sharing! That looks clean!! I like that a lot.
HoosierDaddy
__ Eric
The Base steelie is the limiting factor because it is so skinny at 7" wide.
Other factory take offs are a great move on the cheap .... also Ranger wheels.
Get into the 17 x 7.5 or 8 or 8.5 and the vast majority of tires AT or MT tires will fit the wheel.
NOW ... what will fit the Bronco?
If you do not intend to wheel hard, I have seen several, including my own, fit 35" tires on the Base with NO LIFT.
I bought Method 17 x 8.5 wheels with a +35mm offset and Toyo 35 x 11.5 Open Country AT3.
This set up works with my manual and 4.46 gears, but it is a touch under geared now.
It actually drives better than it did on 30" tires, where it felt VERY over geared.
If you have an auto, maybe consider stopping at a 33" tire ... but I may be wrong.
Mine .... link
Before:
Ford Bronco Tires 20211008_230332
after:
Ford Bronco Tires 20220101_225316
Here is a 35 x 12,5 on factory Ranger wheels, NO LIFT, one of my favorites.
https://www.bronco6g.com/forum/thre...-size-tires-ford-ranger-wheels-no-lift.20733/
Ford Bronco Tires 1641774382144
HoosierDaddy
__ Eric
Mine .... link
Before:
after:
Ford Bronco Tires 20220101_220136
Brizzo1432
Jeremy
Denver
Trailblazer ss
Mine .... link
Before:
after:
Those 35’s look amazing! It completely changes the look of the Bronco.
HoosierDaddy
__ Eric
I'm still amazed they fit with no lift.
No rub in my daily drives.
The guys at work are STUNNED at how much it changes the look.
It went from mail carrier vehicle to ....
Ford Bronco Tires 1641785999781
Ford Bronco Tires 1641786069159
