Tire Deflator Kit recommendations?
Sampsonrustic
Sampson
SoCal
F150 4x4
That’s not necessarily true, it will take you much longer and the fun starts when you break a valve stem. But go ahead and learn the hard way, to each their own.
no joke in there, only experience.
To each their own! I’ve aired down many many times with only a gauge at the beach and on the trails and never broken a valve.
Toccoa
Isuzu Rodeo Sport
Ford Bronco Tire Deflator Kit recommendations? 1612660448314
Guaranteed to work every time.
AzScorpion
2019 Ford Ranger SuperCrew Lariat 4x4
Wow that’s a lot of cash for something I can do for free with my finger and 5 minutes.
Hmm there’s a joke in there somewhere...
They are pricey but after you've bought the cheap $20.00 ones and they fail it's money well spent. Plus these you just screw them on and once you've made your way around all four tires they're usually set. Another big bonus is you don't have to kneel down and wait while the tires are deflating which most will understand as you get older. 😜
mrjerry469
mrjerry469
JERRY
BLACK DIAMOND
How often and how far are you going to air down?
I just use my air gauge with a pressure release button. Takes about 5min (all 4 tires) to go from street pressure to 25ish for forrest service roads.
Don't really need anything fancy for airing down/up. You can also just pull the valve core and do the "knee" check to get you close.
This one looks nice, I may need to order it, I like that it screws onto the valve stem.
https://www.amazon.com/gp/product/B...ga-20&linkId=0c1401a558756cb2770ef66d98c22900
Probably only three seasons and hopefully weekly I'm leaning toward the ARB deflator with the valve. Just keep it simple for now I think I have other accessories I would like to buy first . Thank you all I will follow the links provided.
Apples
Nick
2022 Jeep JLUR, 2024 Nissan Ariya
I've used both the ARB deflator and the Stauns. I generally always air down to the same PSI (15 PSI) so the Stauns work great. Less than a minute to screw on all 4 and then BS with whomever you're wheeling with until you hear them stop hissing. No bending over each tire individually or checking the gauge repeatedly.
The ARB stays in my recovery kit , in case I want to air down to a different PSI for some reason or someone else needs to borrow it.
85_Ranger4x4
Iowa
1985 Ford Ranger
The thing I like about the ARB is it can bounce between trucks. I can use it on the trail with my Ranger, use it to drop the tires to almost flat so my '150 can get under the camper and someday maybe I can use it to air down the Bronco also.
2Jeeps&PatriotX1
Denver, CO
My coyote deflators can do that as well. I air down to the same psi whether its my f150, wife’s grand cherokee or my jeep. I keep the arb in the camper trailer now.
rlynch356
Rob
Apex NC
Defender 90, RRC TDi, 200 series
ARB deflator .. it works, its simple.. and does not loose the setting like the auto deflater ones... staun and the copies, which I own as well but no longer use, are ok but ...honestly you have to test them to see what they are actually set at, generally its 18psi.. but f'ing with 4 of them to reset them to 15psi or whatever.....reliably is a chore.. I find it far easier and faster to do all 4 tires with the ARB
