Thoughts on 1-1.25" level kits
JL8jeff
Ewing, NJ
Does anybody have any good or bad comments on some of the 1-1.25" level kits? My base Sas sits about 1-1/4 to 1-1/2" high in the back so I'm not sure if I should go with a 1" or 1.25" level kit and wondering how those kits worked out for people that installed them. I'd rather be a little short and still have some rake vs the opposite and too much lift up front. I see the RC 1" has 2 spacers up top and was wondering if that leads to any adverse issues vs a single spacer up top. Also, has anyone measured the thickness of the top spacer and lower spacer in case I decided to just install the top one. Thanks for any insight.
Ford Bronco Thoughts on 1-1.25" level kits cact_bronco3
JL8jeff
JL8jeff
Ewing, NJ
I find it interesting that the RC and Zone 1" level kits have new lower bolts/nuts and have the upper and lower spacers. The Readylift 1.25" has the upper and lower spacer but still uses the stock lower studs which makes me think it has to have almost no threads left after putting the stock nut back on.
BroncoAZ
Mitch
Load up the truck with your standard camping load and measure again. Mine fully loaded with gear still sits about 1” high in the rear (Picture). I have purchased the Zone and Readylift kits, not sure which one I’m going to install. I prefer the construction of the aluminum Readylift kit, but the 1” of the Zone might work better. I would also consider doing a coilover setup with 2” lift front and 1” lift rear. Unfortunately we will be buying a house shortly and my Bronco funds will evaporate.
Ford Bronco Thoughts on 1-1.25" level kits 152C05F9-8294-47AD-B153-BF4471659D34
Copperhorse73
Justin
Mooresville, NC
I used the Rock Krawler 1” front level kit. The entire spacer is on the bottom . Had good results
Mudlight
Brent
Badsquatch
I installed the RC leveling kit and added spacers as needed. At least you can fine tune the lift to your liking.
[DELETED MEMBER 27901]
Wheels look great! What did you end up buying for those?
The same AT3's have been serving me very well but long term I would pick up a black set of wheels like yours.
Lak34ers
Troy
Seattle
You can look at Bilstein adjustable 6100 shocks. I'm leaning this way vs adding lifts. Always can adjust and move to 37s in the future.
