Third Brake Light Extender
Drew
Richmond
2022 Base Bronco
Hello all. My Base Bronco is set to arrive in the next 3-5 days. Already have Wheels, tires, 2 in rough country lift in hand just itching to get on the car. Wondering if anyone who has already upgraded a non-SAS to a 35x12.50-R17 has noticed whether or not a third brake light extender is necessary, or does it clear the tire as is? Thanks for the help in advanced.
laxnate
Redondo Beach, CA
Alfa Romeo Giulia Ti Sport, Ford Bronco
I put the same lift and tire size on my non-SAS Base and the 3rd brake light relocation is definitely needed unless you’re OK with it being almost completely obscured. I added the Rough Country one and it works great.
BaseBronco2022
Drew
Richmond
2022 Base Bronco
Awesome. Thanks very much.
TxBowTie
Jason
19 silverado
I have the same setup and it is definitely too short. I just used a piece of 1/8" aluminum 4 holes and a slight bend.
Ford Bronco Third Brake Light Extender 20211205_120419
HoosierDaddy
__ Eric
NW. Indiana
Best shots I currently have of my 35 x 11.5 spare on a 17x8.5 +35mm offset wheel.
The light is resting on the tire. I'd imagine it is blocking the view for the folks down low, up close, in cars.
Ford Bronco Third Brake Light Extender C9E32D95-121C-495E-911D-F40ACB720355_4_5005_c
Ford Bronco Third Brake Light Extender 0FCBA5F4-1BFA-4A6B-8512-DFF2D0326C89_1_201_a
Big Diamond
Miles
Atlanta, GA
2022 Bronco HOSS 3.0 Wildtrak
Anybody with the brake light extender with a soft top?
I've heard that the top may rub on it, but not sure if that is just the extender or the relocation kit.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
I installed the RC extender. The brake light post is now resting on the rear wiper. Does anyone have this problem? Or just ignoring since no one actually uses a rear wiper?
kodiakisland
Arkansas
No, mine doesn’t contact the wiper.
Bronc6g22
Jake
Washington
Interesting. Could be that the entire spare tire carrier is adjustable and just needs to go down a hair. Including some photos for reference.
Ford Bronco Third Brake Light Extender 20230422_154446
Ford Bronco Third Brake Light Extender 20230422_154425
kodiakisland
Arkansas
Not sure if there is any adjustment. Maybe loosen the screws and retighten pulling it out from the top?
Ford Bronco Third Brake Light Extender IMG_3390
Bronc6g22
Jake
Washington
Just added washers under the lower screws to push the top out. See daylight now! Should be OK.
Ford Bronco Third Brake Light Extender 20230422_162108
Ford Bronco Third Brake Light Extender 20230422_162128
