The "Mando" Build
TheBroncolorian
Tampa, FL
What I started with:
2022 Carbonized Gray 4 door Outer Banks High Package soft top 2.3L 3.73 gearing
Ford Bronco The "Mando" Build 01215B89-0BC0-4F57-8E7A-31936F5FD12D_1_105_c
1st Mod: IAG Performance EZ-Lift soft top assist system
https://www.iagperformance.com/iag-...-system-for-2021-ford-bronco-4-door-soft-top/
2nd Mod: 4x4graphics LLC metal fender badges
https://www.etsy.com/listing/1173993409/ford-bronco-outer-banks-outer-banks?click_key=7d6c777b18751858bea52dc26b2279f64636a96d:1173993409&click_sum=62eacc65&ref=hp_rv-1&frs=1&sts=1
Ford Bronco The "Mando" Build IMG_0507
3rd Mod: Oracle spare tire brake light & Rough Country Tail Gate Reinforcement w/spare tire relocation
Ford Bronco The "Mando" Build F4BAD56D-B16F-4A2C-871C-41FD493AC90C_1_201_a
4th Mod: RTR Tech 6 +30 offset wheels & 315/70/R17 Nexen Roadan MTX "All Terrain" tires (swapped for BFG KO2s - 08/22)
Ford Bronco The "Mando" Build C1409590-B943-4BE4-9A04-719B1F8657DB_1_105_c
What's next:
1) Standard to Capable & Steel bumper swap (In-Progress)
Ford Bronco The "Mando" Build AD3AF96F-07BB-4CFA-9B0F-426681710249_1_105_c
(Still awaiting front sensor retainers for Capable bumper. Rear needs non-SAS end caps and it'll be 100% installed) ~ finished late 2022
2) 2 Inch Suspension Lift (On Hold pending market options for coilover setups or SAS takeoffs) ~ Rough Country 2” Spacer Lift installed
3) ADV Modular Black UV Hardtop (hopefully I get it by January 🤞🏽) ~ cancelled
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
What's next:
3) Hard Top...eventually? If one ever materializes for purchase.
Are you referring to the Mandalorian? If so I'm in love with your Bronco.
Edit: Saw your username; I love your Bronco
TheBroncolorian
TheBroncolorian
Tampa, FL
Indeed I am! The sunlight hits this paint and the metallic flake jumps almost exactly like the beskar steel from The Mandalorian. It’s that extra cherry on top with washing it.
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
Jeffola
Southeast Florida
2023 Bronco, 2023 Hyundai Santa-Fe, 2019 GT350
TheBroncolorian
TheBroncolorian
Tampa, FL
How was the swap? I’ve found both but the rear has no sensor bezels.
The most tedious part of the process was obtaining the sensor retainers for each bumper, as no two Ford parts departments know what the Capable bumper is, or what these plastic retainers are. I also had to modify my retainers to fit by shaving down the sides to fit the slots of the bumper (even though both the website and the sales guy said they would fit).
The actual wiring harness swap over was easy, it just requires patience to route it in such a way that the wiring becomes semi-invisible (zip ties are your friend). From there, it’s just having an extra set of hands to bolt things up and not drop anything on your face in the process. One thing to note is the plastic bumpers have an additional bracket to bolt into that you’ll need to remove to get the steel bumpers to marry up 100%.
Jeffola
Southeast Florida
T
Thank you so much. Any idea on the rear bumper sensor bezel part numbers? It’s crazy but I can’t search for parts online. Just accessories
JBlanco
Julio
Charlotte NC
So, you will constantly say you will never take the top off but then you will?
Ford Bronco The "Mando" Build 1684763254206
TheBroncolorian
TheBroncolorian
Tampa, FL
On a technicality, I’ve never taken the soft top completely off of the vehicle…I’m still a Mandalorian right? 😅
TheBroncolorian
TheBroncolorian
Tampa, FL
TheBroncolorian
TheBroncolorian
Tampa, FL
Completely forgot to add my RTR grill to the progress list as well:
Ford Bronco The "Mando" Build 69447879666__29E157A8-3B69-4643-9F8D-8310C43F8005
Ford Bronco The "Mando" Build CD6A1A93-7006-40A2-8466-9930245335C7
