Tapping into the reverse lights
Singleshot
Oregon
Silverado
I've just installed the rough country rear bumper with the two (2)slim-line 6" LEDs. I am also running the Oracle taillights.
What I'd like to do is tap both rear taillights to power each slim-line 6" light. According to Rough Country, the am draw on the slim-line's are 8 amp each. I have not contacted Oracle about the amp draw on their taillights, but I'm assuming that it's similar to the OEM LED taillights.
Does anyone know what the draw amp on the reverse circuit/taillight circuit so I can see if this is feasible?
Thank you
Singleshot
Chrome_Pony
Chrome
The Great Land
Worst case you tap it and use that as a signal wire for a relay wired to the slimlines.
broadicustomworks
Hanging Rock, North Carolina
Or you can get the reverse light tap harness from StickerFab and wire up the extra lights to that, not mess with the factory wiring with taps/splices.
toymaster
Leonardo
Wyoming
2023 Badlands
It is highly unlikely those LEDs are drawing that much power. However I'd use a relay. Also it may be handier to have them on their own switch.
Singleshot
Oregon
Silverado
I appreciate the responses. I had a brain fart and forgot I had the 7-pin harness, which I will never use...
So I just tapped into the center wire (backup lights) and wired them that way. It was literally right there... I didn't want it switched, as I'm too lazy and forgetful to put it in reverse and then hit one of the aux switches just to back up.
It's done.. Bumper installed, lights work (but hard to adjust) and the wife is happy.
Thanks again for the responses.
Singleshot
Johnny Mo
Westchester County, NY
teachu2shoot.com
I plan to use the Stage Series C1R 7-pin Dual-Output Trailer Wiring Harness from Diode Dynamics for a set of KC Hilites C2 Backup system - was told no need for relay on them since 3.3 amp draw. Just not sure how it will potentially wash out rear camera - so may wind up switching to Aux switch if that becomes an issue.
