Tailgate Table recommendations!!!
KlynB95
Kailynne
2024 Bronco
I am looking to get a table of some sort. What are the best options out there!! Or was thinking about the pull out tailgate!! HELPPP!!
WheresMyBronco
Los Angeles
2023 Badlands
I bought this for ~$60 a few weeks back (no idea why it was so cheap) but it's very solid and doesn't rattle at all
https://a.co/d/eq0HlSP
Use the install video (last pic on this listing) and you'll be able to do it within an hour
https://a.co/d/9mz0opK
Most of the bad reviews are because they had difficulty installing or were missing a latch/some hardware. Just follow the video and make sure everything is in there before you start and you'll be good
I have the Turn Offroad tailgate table. I don't really recommend it, the latches are constantly coming lose and rattling. I'm about to remove the latches and just put in wingnuts or something.
Apart from the latches it's a nice piece of kit, but those latches are junk.
Roach
Houston
'15 Frontier, '74 FJ40
I’m going with this one on Amazon.
JROAD Bronco Double Layer Tailgate Table for 2021 2022 Ford Bronco 2/4 Door Rear Foldable Cargo Shelf Storage Shelf MOLLE Panel Bronco Accessories https://a.co/d/6Eaco0o
Roach
VirginiaHeritage
Frank
‘25 Bronco HE
The OEM slide-out tailgate locks in the open position and is rated for 600 lbs. You can stand on it for roof access or seat two people on it for tailgating. It came pre-optioned on mine and I wasn’t sure I would keep it until I took it camping. Now I’m sold.
Ford Bronco Tailgate Table recommendations!!! IMG_1740
Ninjak
Miami
Running the one that @Glade Runner has. Ford Slide out Talgate with BroAddict Fold Down Molle table.
Ford Bronco Tailgate Table recommendations!!! 1748023746421-b5
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
If you like expensive things, I can highly recommend the Trailgater.
I also have the slide-out tailgate @VirginiaHeritage mentioned. I'll admit I was skeptical, but you don't really realize how awesome it is until you go camping a few times.
Turn Offroad
Cole
2021 First Edition
The latches are adjustable. Have you tried adjusting the landing post in or out to help with this?
I just did that actually - still fiddling with it. Somehow I made it worse, even though it feels like it’s latching tight. It’s a pain.
Between that, the ring nut holding the button on coming loose and the bushing holding the spring together coming loose and nearly losing the interior pieces, I’m about to junk these latches.
The button/bushing I’ve even tried loctite - just not enough threads to really bite on, and that bushing needs the key to really get tight, me just jimmying it with an awl probably isn’t cutting it.
BUT - I appreciate the reply!
coadr
Coady
Denver, CO
2022 Ford Bronco Badlands
I'm waiting for the Versatable from AAL to drop for the Bronco. They've teased it a few times, hopefully it'll be sooner rather than later
CoolContractor
Fred
I'll second the Trailgater. I bought this after watching your review. I ordered an extra plastic cutting board that stows inside the table when closed but provides 2 side extensions when open.
Rick_DRZ
Rick
Maine
2022 Bronco, 2021 MB Sprinter, 2020 BMW x7 M50i
Ninjak
Miami
KlynB95
KlynB95
Kailynne
2024 Bronco
The tailgate looks awesome! I think I’m going to go with this!!!
