Tailgate not locking
jpaulsbronco
Shane
Winston Salem NC
2024 Bronco Black Diamond 2 door
My tailgate will not lock when using the button or key fob. Proximaty works on the back handle and it shows the tailgate closed on the dash. Does anyone think the latch is bad? Is that a known issue with the broncos?
Valhalla
Valhalla
Chattanooga Tn
Could it be from the handle upgrade you did?
BigRed26
B
Illinois
2026 Ford Bronco
Exactly the same with my tailgate handle. My service dept had to replace the handle. No explanation for the failure.
jpaulsbronco
jpaulsbronco
Shane
Winston Salem NC
It was working fine and I can lock the truck with the button on the tailgate just not the tailgate.
jpaulsbronco
jpaulsbronco
Shane
Winston Salem NC
I did install the oem hitch, could that be an issue?
MRinaldi
Did you unplug the antenna for the auto lock/unlock?
jpaulsbronco
jpaulsbronco
Shane
Winston Salem NC
I just checked and it is plugged in, not sure what is going on
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
When experimenting with Forscan awhile back looking through the options for my 2 door big bend, I recall an option that said something like "2 door" vs "4 door". Not sure it was these exactly but something like it. My setting at that time was 4 door and I switched it to 2 door thinking that's what I own. When I did it, the rear lock button on the tailgate handle stopped locking the truck. I switched it back to 4 door and it worked normally again. Just a thought.
jpaulsbronco
jpaulsbronco
Shane
Winston Salem NC
Thanks, I checked and my 2 door is set to 4 door so I left it like it is.
Quatermain
Idaho
2025 Bronco
Did you program it? I installed the OEM hitch kit and it did mess up the rear proximity alert. Took it to the dealer and had it programmed and that issue vanished. No problems with the handle or locking.
jpaulsbronco
jpaulsbronco
Shane
Winston Salem NC
Yes I programmed it, ran test in Forscan and it just stays locked even though it is not locked, never changes with the handle or key fob, like I said I can unlock and lock the doors except the tailgate with the tailgate handle
jpaulsbronco
jpaulsbronco
Shane
Winston Salem NC
Tested with multimeter
Pins 1-2 I get 12.3 v
Pin 3 I get 0.00
Pin 4 I get 5.55 v
does anyone have a pin diagram for the harness?
