Tailgate Molle panel (not table) recommendation?
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
I'm looking at replacing my current tailgate table with a Molle panel. I don't really use the table function, and I'd rather save some weight and noise. I've seen a few different options out there, but I'm looking for some recommendations from anyone who has any direct experience with any.
BillTheCat
Alaska
4Runner; Bronco: BB/SAS/LUX/2DR
I went with THIS one from Amazon. There are several out there, and some better/more expensive.
But this had free shipping up here. Elsewhere the shipping doubled the price. YMMV.
Very happy with it. Totally LOADED it up. 1" velcro. Zero rattle.
not on the rug
2024 Wildtrak. 2011 BMW X5M. 2024 Nissan Pathfinder Platinum
I have the Ford one that I bought with Ford rewards points. No issues. Easy install. No rattles. It's all loaded up now but here it is after install.
Ford Bronco Tailgate Molle panel (not table) recommendation? 20250902_174303
murrman
murrman
Sean
Toledo, OH
Thanks! Do you know if the Ford one is the same as the Putco one? They appear to be identical, but I can't find any confirmation.
not on the rug
Yes. If you look at the description under "technical specifications" is shows the brand as putco
murrman
murrman
Sean
Toledo, OH
murrman
murrman
Sean
Toledo, OH
As another option to compare I have the @Mountains2Metal tailgate Molle. Code BIGLUC can save you a little money if this one interest you.
I seriously considered this one because I have quite a few M2M products. The only thing I don't like is how it leaves the wiring along the upper edge exposed. Gives it a slightly unfinished look in my opinion.
BD6G
Everglades
IN
24 Bronco
Everglades
Yeah does leave that area open due to the mounting hardware in that location. I’m with you on having a lot of their products I’m a big fan of their stuff.
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
I got an open box special Havoc Off-road panel for $72 from extreme terrain. Been very happy with it - no rattles or noise that I can tell.
Ford Bronco Tailgate Molle panel (not table) recommendation? PXL_20260530_122027245.RAW-01
Richmond, Virginia
2007 Toyota FJ
Question from an impending Bronco owner. Do all of these Molle panels mount to existing bolt holes on the tailgate, i.e. don't require any drilling or irreversible modifications? (I'm coming from a Toyota FJ that I put Molle panel on back gate, want the same in the Bronco)
GA2Dr
Marietta, GA
The Havoc one I have requires no drilling - bolts into existing holes. I can't speak for all of them, but I believe the vast majority of them are the same - no drilling required.
murrman
murrman
Sean
Toledo, OH
It depends on the panel. I know the Putco/Ford one and M2M ones don't require drilling, but the ADD and DV8 ones do.
