Tailgate molle panel not fitting correctly?
Stroopaloop
2019 GMC canyon all terrain
So both the dealership and I tried to install the molle panel on the tailgate. Both ran into an issue where the hooks don't quite match correctly. Also noticed a terrible sag on the top of the panel as well. Anybody else running into an issue with the installation of this accessory?
Tmurder1776
2021 Bronco Base
I thought I had read an install and they had to add a little bit of velcro or something. Can't speak for the hook issue though. Maybe you got a bad one?
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
One of my top hooks came unstitched. before it came unstitched it sagged.
I ended up using a zip tie up top in place of the hook and that resolved my sag as well. They should have supplemented the top with velcro.
Delight
Delight
Cincinnati
Sequoia
Mine has a little sag on the top right. It’s been that way for 3 months now…when it warms up I’ll probably try some Velcro.
threeonone
Canada
Jaguar
I really had to pull hard to get the clips to fit in mine. I used pliers to pull the hooks down while using a screwdriver to open the hook up a bit more to angle it in the slot. Velcro all around the edges but cut a groove for the cables.
Ford Bronco Tailgate molle panel not fitting correctly? C977F23B-97D1-45B0-AEE6-08EB86ABE6A2
Ford Bronco Tailgate molle panel not fitting correctly? B64C9B01-1378-4889-8AE4-508193A4DEA8
threeonone
Canada
Jaguar
Also may be a dumb question but did you remove the plastic piece on the tailgate first before trying to install it?
Stroopaloop
Stroopaloop
Yup you have to in order to access the slots where the hooks go. My issues are the sag when all four hooks are in the top slots and the pita of trying to get everything to fit correctly.
Stroopaloop
Stroopaloop
I'll try your tips, but I'm looking at your pics and wondering if I got a bad MOLLE panel. Guess I'll see when I try it later. Where I circled is where I'm getting the sag/puffing out.
Ford Bronco Tailgate molle panel not fitting correctly? Screenshot_20220127-142032
DentonDreamMaker
Claire
Northlake TX
Ford Explorer, Jeep Wrangler, 21 Bronco Outerbanks
Yes!
I ordered some for a customer and they didn't fit on his Bronco or mine, we returned it and ordered more & didn't fit!
threeonone
Canada
Jaguar
Weird. Maybe it's bad quality control on their end. It was super hard to get in but it feels really sturdy once it's in.
Dirty Bronco
Brad
Charleston
2021 Ford Bronco - 4 Door Badlands
Mine came in the mail yesterday. I installed today. Wish Ford told you how to remove the plastic "Accessory Ready" panel. After I figured that out the installation was a breeze. I had no issues with the clips lining up.
Ford Bronco Tailgate molle panel not fitting correctly? 1643650679911
LarryZiegler
Larry
I ordered one and had it installed prior to purchase and everything aligned perfectly upon inspection of the installation.
Ford Bronco Tailgate molle panel not fitting correctly? 54321310-5631-43CB-8B73-7DAE24E61749
Shacky4
Sault Sainte Marie, Michigan
Big Bend Bronco
Did you use tape backed velcro? Just on the top or all the way around?
