Sync split screen?
Area51BS
Ron
Badlands non SAS 4dr 2.3
Went on a road trip yesterday and had phone connected with nav and CarPlay split screen by tapping little square on bottom left. On return trip I wanted to do the same so I didn’t miss a turn. However I could not get split screen. If I recall the little square on bottom left was different and just brought me to the radio menu for all selections. CarPlay, Ford sync etc. Ended up just toggling screen between nav and music.
crzyhawk
Virgina
2024 Bronco, 2008 Mustang
It's the button in the corner, I circled it in yellow
Ford Bronco Sync split screen? radio
crzyhawk
Virgina
When it's not in split screen mode, you have a box. clicking the box toggles you between full and split screen mode.
Ford Bronco Sync split screen? radio2
Area51BS
Area51BS
Ron
I didn’t have the box in second pic on way home but did on way. On way home I had the 1st pic you posted and couldn’t get to split screen. Wait! Found it. The empty box allowing split shows up on app screen. Thanks. Resolved.
Ford Bronco Sync split screen? imag
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
How did you get CarPlay to fill up the entire display (without the Audio, CarPlay, Apps, Settings, Features buttons below)?
crzyhawk
Virgina
if I had to hazard a guess, he's got the older, smaller screen
Area51BS
Area51BS
Ron
The square of 9 little squares brings up apps. Just select music.
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
Upper left corner there is a double arrow probably pointing inward if you don’t have the full screen. Press the arrow and it will enlarge and fill the screen and the arrows will change to point outward. Does that make sense?
