Switch-pros
BroncoRunner23
2023 Bronco
anyone install a switch-pros to their bronco ? The modules 3 led lights flashconsistently when with key off. I tried searching if that’s normal but can’t find anything.
I installed mine today but don’t have the switch panel plugged in since my lights aren’t here yet just wanted to get it in so it’s ready.
I think it’s normal. I followed the instructions and doubled checked I did it as directed
if it matters the model I have is SP9100
BroncoRunner23
BroncoRunner23
2023 Bronco
I have it in my Bronco, no flashing...
thanks for the reply. Not sure why I didnt just plug in the switch and see if the problem goes away. I did just that a little bit ago and the lights turned off. found my issue
AK SNO RIDER
Ty
Alaska
Glad you figured it out. Just wanted to chime in and say you're gonna love the Switch Pros. I have the Force-12 and am very pleased.
The Bluetooth can be pretty finicky to get synced for the first time. If you have an Android, make sure to go into the app settings and manually grant every permission.
Definitely do it though, because it makes programming the unit 10x easier, and allows you to run all your equipment remotely without the ignition on.
BroncoRunner23
BroncoRunner23
2023 Bronco
Thanks, ya it’s a pretty nice unit. Just waiting for my ditch and fog lights to get here and I will play with its capabilities.
