Swing Gate Strut gives up the ghost
DWood
Dustin
North Florida
Update: 9/7 service department documented and ordered a new strut assembly.
Did a search and came up with nothing similar so decided to make a post. Yesterday morning the wife and I took our Black Diamond out to the beach. Upon arrival and opening of the swing gate I was greeted with a pop quickly followed by a metallic ting. Investigation revealed a previous single part now in two pieces.
I’ll be headed to the dealer service center shortly to document but I do believe this will be a common issue. The swivel “ cap end” of the attachment point on the gate side is a plastic/polymer construction. The steel treads from the strut simply decided to check out along with some plastic. 9/16 will be 2 months of ownership and I currently have 3800 miles. Now I will say I’ve opened and been into the rear a lot over this period of time however I do not see this design holding up over extended use regardless of how easy you open or close the swing gate. Pics below, I will update future developments. For the record I did not snatch or heavily force it open.
also it is kinda nice without the strut if only it had a limiting strap to avoid any possible damage at full open.
Ford Bronco Swing Gate Strut gives up the ghost 3EEDB62E-D404-48D3-9A94-437B527F3B72
Ford Bronco Swing Gate Strut gives up the ghost 94D0665A-FD89-40C2-99C0-891281727CAC
Ford Bronco Swing Gate Strut gives up the ghost 31FAF0C6-3E4C-4525-BFC0-7685E2AA2FE3
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
That stinks. Thanks for documenting and keep up updated on what you encounter on the repair. I agree that a limiting strap would be handy to avoid opening it too far with the strut damaged.
Carolina Jim
Highlands
2021 Bronco 2-door
So....are you saying the threaded male end stripped the female threads?....or was there a bolt of some kind that came off?
GaryB2220
Gary
Wellsboro PA
Unfortunate. Hope the engineers add this to the fix list for 2022
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
A limit strap would keep this from snapping off. It broke when it hits the end of it's travel trying to stop all that momentum.
Lab00Rat
MS
2022 BL 2-Door, 2021 Ford Ranger
Was it a pull strip or a push strip?
Like, did you open too fast and pull the strut out, or did you open to slow and it pushed it self out?
ReimundKrohn
Reimund
Three Hills Alberta
2016 Rav-4, 2005 F-150 Lariat, 2005 PT GT Conv
I really questioned this design aspect - the hydraulic strut on the swing gate. A strut aligned horizontally doesn’t add rigidity or strength to the gates travel; in other words, hydraulic or pneumatic struts are intended to bear a (compression, not extension) load at their end points, and not along the length of the shaft.
I presume Ford added the strut so that they could still mount larger tires on the swing gate without having to add hardware secured to the frame or modular bumper, as Jeep does if you opt to go up in tire size. Another short-sighted “innovation” in cost cutting, I suppose.
broadicustomworks
Hanging Rock, North Carolina
Hmm. Very, very interesting, and now explains what I saw on a dealer demo last weekend (or the weekend prior).
When we were looking at it I noticed the strut was just lying there, unattached.
I assumed they removed it by threading off that end, and simply reaffixed the end back to the gate (to keep it from getting lost) for whatever reason.
But it was an identical look to what you have.
So apparently that's two we know of with the same fail.
Good to know, as now I'll treat my gate with extra care once I get mine, and until they come out with a recall/replacement.
DWood
DWood
Dustin
North Florida
Correct, female threads are merely polymer. there doesn’t appear to be any metal reinforcement within the end swivel cap as far as threading goes. If you zoom in on the first pic you can see the plastic within the male style threads
it was about 1/4 of the way open right where you meet the first bit of resistance when it gave way.
Sounds familiar, every time the gate is opened the threads are being pulled on. Only a matter of time
Carolina Jim
Highlands
2021 Bronco 2-door
All I can say is WOW. If Walmart started making cars, this is about what you'd expect.
Th is tells me Ford has exited the car business & believes they're now just selling electronic toys.
da_jokker
Jeep Wrangler JKUR
I wonder if there is enough meat to put a helicoil in there...of course I guess that could just strip out as well.
Too bad you couldn't drill a hole through it and put a cotter pin through the whole setup.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Curious...Does your hinge have the updated travel stop?
Ford Bronco Swing Gate Strut gives up the ghost orYVsBB
New:
Ford Bronco Swing Gate Strut gives up the ghost s3su5Xl
broadicustomworks
I'll bet ya could, just have to be precise and a bit gentle. Good thought.
I'll bet the first company to come out with non-plastic end struts will make $$$.
Might have to just measure it and get a replacement off the rack at the auto parts store. One with metal ends.
