Virtual-Chris
North Vancouver
This seems amazing to me. I wouldn’t have thought to even try this. I’m going to have to man up! 😛
da_jokker
Jeep Wrangler JKUR
here's a few key frames...
If that is a disconnected sway then I feel bad for those all exited about it. He didn't even have his locker on, you think he went through the trouble of disconnecting the bar.
I could be wrong. But that left front is barely dropping.
Offroadrob
Rob
Summit county Colorado
19 TRD PRO, 10 Cayman S
Those RTR wheels?
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Those trail/ridge grapplers definitely make a difference too. I have a feeling the stock Sasquatch tires are leaving the dealership in the back for me
Is this a video? not showing for me. is it on youtube?
Pictures look great in other peoples posts!! i would love to catch the video.
Nickp
Nickp
Nick
Phoenix
Yup it’s an Instagram video! Weird you can’t see it it’s linked right in the OP....
Here’s a link that won’t imbed!
https://tinyurl.com/s6nntbpd
vrtical
Doug
GSMNP, TN
Fords
pretty sure I am getting some Nitto Ridge Grapplers 37x12.50s for my park tires.
vrewald14
Vince
Iowa
03 Ford Excursion, 79 Ford Bronco, 04 Toyota Camry
Absolutely badass video. Love it!
So glad I chose to go Badlands.
ferbm
Matt
Rochester Mn
Couple SUVs, couple clunkers, one sweet ride.
I guess those worried about the droop will have to wait for an electronic SFA gizmo that "links" the IFS so that it droops more like SFA on the trail, but can be disengaged on the highway or high speed trail running.
Until then, you should cancel your order.
luptanpitman
Los Angeles
'21 Bronco, ‘21 Polestar
nothing makes me happier than watching this knowing Ive got the exact specs other than color and a VIN/build date of week of June 7th. This post made my year.
UNBROKN
Central Virginia
Thanks. Not sure why I can't see it either. Maybe it will hit youtube before long. I don't do instagram.
internationlriders
Josh
Alberta Canada
2021 Bronco Badlands
That's a lot of flex for an IFS! Mighty impressive! Although Jeeps are great performers, you would still ideally want a lift kit and some bigger tires to compete with the SAS pack. Another reason why I chose Bronco over Jeep #99 problems and a Jeep ain't one
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
'79 Mustang, '92 Explorer, '10 F-350
Umm. This is more of a demo as to why a front locker is needed with IFS for doing this type of off-roading. My XJ has more front flex with the sway bar connected than the BL with it disconnected—hence why (with the sway bar disconnected) I can tackle the same terrain without a front locker. This video has me seriously doubting my BD order now. Oh well, it’s too late, as I’m one of the lucky ones with a scheduled June build.
The reason he had to use the front locker has much more to do with the spacing of the stairsteps than the IFS.
MoabRox
Two Jeep XJs, Dodge M880, Suburban 2500
Although that is definitely a contributing factor, I disagree that it’s more so than the IFS. If both front tires have traction (weighted contact with the rocks), it’s simply easier to climb ledges (with or without a front locker). I’ve wheeled most of the Moab trails with IFS and SFA rigs. When it comes to rock crawling, a SFA performs (flex) better so you can get away with fewer mods like a front locker.
