Swapping Stock Tires & Wheels for Wider
Black Braptor 22
Hello.
Does anyone know if you have to modify or shave your wheel well to install 13.50R or 14.00R tires and wheels on the Braptor?
I have the stock tires on my Raptor and don’t want to change the 37” wheels but looking to go wider.
I have gotten conflicting information from Tire and Body shops on whether they can just be swapped or need further adjustments.
I currently have the stock 37x12.50R17 tires and wheels with a 1.50” spacer installed and evrything runs smoothly with no problems. So it doesn’t make sense to me that I would have to shave or make any mods to the wheel well but maybe I am missing something.
Thanks!
swamp2
The Raptor has some pretty good clearance for stock tires as it also needs to accommodate mud, gravel, snow chains, etc. I've not run them myself, but I do run 0 offset wheels which is very close to a 1.5" spacer and all is fine. Thus, I'm reasonably confident that either of those widths would be fine (with no spacers).
hec1
Hector
2022 F150 37PP Raptor 2024 Shelter Green Raptor
Running 13.5 on stock. Zero issues
Black Braptor 22
Thank you for the info!
