Superchips - Flashcal - Updated for 2023 Bronco
Az_Squatch_Bronco
Shawn
Tucson
Bronco Badlands w/ sasquatch pkg - Carbonized Grey
I had been reading that the FlashCal for the Bronco was not ready for the 2023 rigs yet, however, I did run across one post where someone said it did work. I ordered the Flash Cal (1546) via Amazon with one day delivery. I updated the unit and was able to change the fog lights to always on, disable double horn honk, and adjust TPMS.
I am having 37" tires installed Monday - I will adjust the tire size and see how that goes.
Ford Bronco Superchips - Flashcal - Updated for 2023 Bronco 20230730_133413
Arokcrwlr
Kraig
US - Alabama
Did you have to download an update for the Flashcal, or did it work out of the box? I won a unit about 6 months ago and it didn't work with my 23...
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
I updated it as soon as I took it out of the box. Its too Hot in Arizona right now to be taking extra steps that would require me to be out in the Sun more than i have to!
Combustion_King
Derek
MA
Yes
what other options does it offer? seems like ForSCAN does those things pretty easy and cheaper. does the auto start stop go away with this
Arokcrwlr
Kraig
US - Alabama
This what it says on the box... You are correct most, if not all, can be done via forscan.
Ford Bronco Superchips - Flashcal - Updated for 2023 Bronco 20230302_094013
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
If Forscan is anything AlfaOBD I use for my Ram, its probably cheaper. With My Ram 3500 I had to buy a security by pass cable, AlfaOBD program, OBD Link, and have a laptop.
Perhaps its slightly cheaper if you have all of those things, this is maybe a little more convenient perhaps.
The Fords must not be locked down like Dodge/Ram -
NikeNeedamyer
Seth
Aubrey6214!!
Bronco, Ram 2500
Please update once you try with the new tires and compare speedometer with gps. Been waiting for this information prior to ordering. Thank you.
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
Tires were supposed to be here today...looks like maybe Wednesday now. So far I have been able to adjust TPMS, set Fogs to on with brights, and eliminate the double horn honk. The Auto/start stop seems to have been eliminated but Haven’t had a chance to drive it enough to verify.
hokie94
Andy
2023 Non SAS OBX
Do you know anything about the Flashpaq upgrade? Cost? Availability for Broncos? Thanks for trying this out on your Bronco...looking at grabbing one of these once I take delivery.
Az_Squatch_Bronco
Az_Squatch_Bronco
Shawn
Tucson
The FlashCal for the Bronco is $199. The updates are free.
So far everything has worked except the disable auto stsrt/stop. I may try to see if there is another update.
New tire size will be on the list later this week.
BroncoRunner23
2023 Bronco
Just received mine from amazon. i have a 2023 and it worked(Came updated). I was able to turn the horn off when walking away with the keys and updated my tire size to 34's from my 30's. For the tire part I wish it would show somewhere, all it did was tell me its been updated.
mhtucker78
Matthew
VA
2023 OBX Bronco
Can you provide a link to a reputable Amazon vendor?
Kowboy71
Houston
2023 Bronco OBX Advanced; Ram 1500 Limited
I bought the same unit off Amazon and was able to calibrate my 2023 OBX speedometer for 34” tires. It took 3 iterations to dial it in exactly to the GPS. I don’t plan on making any other changes (yet)…
