Sudden stop, bent hitch.
Backwater
2020 GMC duramax
I decided to see how the new Bronco toed my 4 seat RZR on a lightweight 18' flat utility trailer last weekend.
The Bronco had plenty of power, and braking. The trailer did push the rear around a little on the highway, but it was tolerable.
While heading home a car cut me off in traffic, and I had to slam on the brakes a bit. Not a full on emergency skid, but definitely firm. I heard a crunching noise, but was only a block from home, so I continued on home. When I arrived, and inspected what the noise was, I discovered the receiver hitch had bent down around 3/4".
Has anyone had this happen? I can definitely see how it could happen. The hitch is fairly thin steel, and not gusseted anywhere. I plan on trying to bend it back, and reinforce, or replace with a Curt, and reinforce before mounting.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
There was the guy that backed into a rock and dented his hitch crossmember, but this is worse.
Can you post pictures?
robepa
Paul
West Seattle, WA
www.instagram.com
2022 Bronco, 2006 Tacoma, 2020 4Runner
@Backwater What height of drop drop hitch are you running? Still shouldn't bend, just asking for context as I'm going to be pulling my off-road trailer well, off-road which is typically more load than an on road stop. I had been eying the the braces from the raptor to the tow hitch.
Backwater
2020 GMC duramax
6" rapid hitch
mike8675309
Minnesota
...I discovered the receiver hitch had bent down around 3/4".
The receiver, or the hitch? Those are two separate things. The receiver is bolted to a frame rail on the Bronco. The hitch slips into the receiver.
Backwater
2020 GMC duramax
LOL... Receiver.
rtazz17
Connecticut
2022 Ford bronco big bend
Lift with weight thats maxed out I think you got what would happen to anyone with that setup.
Oldhippie
Barry
Santa Cruz, Calif.
I’m thinking of mounting the hitch to the bumper as well as the crossmember...stock setup seem pretty light duty to me...
Jdc
Jon
Massachusetts
Bronco Badlands
Damn, this post and the other one make it hard to understand if that cross member is weak or if folks are just putting too much pressure on that cross member.
Tilzbow
NV
GM Sierra Diesel Pick Up
Since you were close to max tow capacity the 6” drop hitch likely created enough leverage to bend the receiver.
